Question about Technics SL-1200MK2 Turntable
Pitch adjustment light is always on
Had my 1210s a few months, my problem is the light that comes on green when you put the pitch adjustment knob to 0. Is always on. The light does get a bit stronger tho, when on 0. does not seem to cause problems with the pitch when mixing, i have done a full pitch test.Looked everywhere for a solution. please please help. peace Dj Nyce
  • lemondj Nov 29, 2008
    I got the same issue with my technics 1200. bought 2nd hand about 8 years ago. changed both pitch faders by professionals since though. however, last week while using my Serato I noticed that one of the decks was producing variable pitches on the digital output on the laptop. I also noticed the pitch fader light was dimly lit @ 4.0. The other deck was fine.
    I took a standard record and played it normally on the decks. Seems to be affecting mixing. either that or im a lot worse than i think i am and have just woken up from a 5 yr dream about being 'alright' on the decks. checked the plate
    no spillages,
    dust possible
    recent movement in flight cases.
    the pitch variance on the deck: +/- 0.4.
    what ya reckon?
    Problem Solver:
  • 6 Answers
I have decided to replace both pitch adjusters on my Technics because they are both more than 15 yrs old. should solve the problem..
next..... the tonearms...
Posted on Sep 14, 2009
  • 515 Answers
Did you buy this turntable used? If so, more than likely the previous owner replaced the pitch control and either connected it incorrectly, or used a pitch control off of a MK3 or MK5 turntable. If you bought this new, and you have been the only owner, the problem could be as TTECH described, either a voltage issue where you have it set up, or needs to be cleaned out. However, if neither of those are your issues, then it's time to get it professionally checked by a service tech. The pitch control is more than likely faulty, and will need to be replaced, but that wouldn't cause the constant LED light from being on. That is usually caused by a bad capacitor or resistor - i would be it's a capacitor that isn't discharging correctly. So, this is where a service tech would come in handy. Sometimes the Pop-up light causes these types of issues. Unfortunately, there is no easy fix. If it's not causing you too much trouble, you can always leave it the way it is. - Justin
Posted on Sep 02, 2007
  • 147 Answers
Ok DJ,I use to Dj too,Probley you have moved the equipment quite a Few times,Is the Table Synchronous if so you might have some dust in you control throwing it off,Also Different locations have ac Voltage differences,Ck that too... Other wise go to radio shack and pick up some Contact cleaner Good luck let me Know ttech
Posted on Jul 24, 2007
SOURCE:
When i turn my 1210s on both 33/45 switces come on and platter spins too fast
Couple of options , but first cleanen the pithfader and variable resistor pitch vr3 i thought, it's an open one , he needs allways to be replaced, even technics says so and first clean the board, inside and on youtube and this side there enough movies and text how to do it, and check the pitchfader cables very good.
Apr 12, 2014 | Technics SL-1200MK2 Turntable
The washing machine will start turn a few times add some water but then stops and the light flashes
Sounds like unbalanced now - try to rebalance the adjustable knobs under the washer - we have to rebalance every few months because our floor isn't the straightest. We always know when its time because the washer won't work right.
Mar 23, 2014 | Amana NFW7300WW Washer
I have a jugs jr pitching machine and can't get the speed to adjust
Take off the cover and make sure the wire is connected to the knob and check the wire maybe it's exposed an not working properly
Mar 03, 2013 | Jugs Small Ball Pitching Machine
High pitch sound from natural gas bbq what is causing this
It sounds like the air mix is wrong needs adjusting too much air to burn
May 26, 2012 | Grilling
What is the thread pitch count for a 1997 jeep tj sport?
Likely it's metric but not always... best (cheapest and quickest) way to find proper thread/bolt size is to get a few nuts from a hardware store and see which size fits...or, remove the shift knob on yours (usually there is a nut under the shift pattern diagram plate...you need to pry it out) and have a hardware store match the thread size. I just put a hurst "t" handle on a friends Jeep a few weeks back but can't remember what size the stick thread was. If I knew the question would come up I would have made a note of that!!!
Dec 04, 2009 | 1997 Jeep Tj
1991 Ford Thunderbird "Idle Knob"
there may be an idle adjustment on the idle air control valve but what happens if you come to a stop and place trans in neutral before complete stop ???
point is that you could be looking at just an adjustment or possible internal transmission problem
Oct 18, 2009 | 1991 Ford Thunderbird
Faint lines show up when i get dark screens in movies
First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
Put TV on any free AV input so screen will be dark enough to adjust screen volts.
Thanks.
Aug 28, 2009 | Sony KP-57WS500 57" Rear Projection...
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Hitachi Plasma EDTV has green dots flickering all over screen
that is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely.
Jan 11, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Sony 65 inch rear projection
behind the front grille there is a wooden panel remove it and yo will see a small black epoxy box with 6 knobs sticking out from it.
with the color turned down all the way, look closely for r,g,b on the box beside each knob this denotes which knob is for which color.
you need to adjust the 1 marked g on the bottom row. this adjusts the green bias to the green tube. this will get rid off the whiteish lines. adjust this knob counterclockwise in a darkened room untill the color shows a black and white picture. adjust slowly as the set will be monitoring what you are doing and will adjust itself as you adjust. bring the green down just enough so you don't see anything, make sure that you don't see red or blue either, if you do also adjust untill you don't see any color. these adjustments should be done with the input set to a video input that has no signal coming in the set will show the input label and nothing else.
when you have the raster( screen ) all dark you can go to an input with a signal and make sure the image is black and white adjust the bias of the color that is too much so that it is black and white.
hope this makes sense to you. now turn the user color control back to where you want it.you are done. reassemble, enjoy
you might have to do this again in a few months as the control you have adjusted are dirty and can't be cleaned with a cleaner.
moving these controls cleans them but the color balance procedure would have to be completed after such movement of these contols and any quick movement would have to be done with the set turned off. a quick back and forth movement will do a better job cleaning the tracks inside that adjustmet block but will mean you will need to do the setup adjustment all over again in order to get the screen blank and the color to balance to black and white. the top 3 knobs are for focus of the individual colos only adjust if the red, green or blue isn't sharp, you can try these to see with out doing harm. finally if thebias is too low then th lifgt on the front of the set might blink at you and the auto alignment might get part way through and stop. if this happens you need to bring the bias adjustment back up slightly. adjust only the bias for the tube that has too much color to start with and if this happens you will know that the bias control you just adjusted is the 1 that needs to be adjusted slightly.
Sep 22, 2008 | Sony KP-53V75 53" Rear Projection...
Technics SL-1200MK2 Turntable Logo
222 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
