Question about Price Pfister Plumbing
Bixby f-538-5lc kitchen faucet hose
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
SOURCE: REcently installed Danze Ashburyee kitchen faucet
Disassembled hose and realized all I needed to do was tighten the brass coupling to the hose. Problem is fixed.
Posted on Jan 31, 2010
  • 35 Answers
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Posted on Feb 23, 2010
  • 10 Answers
SOURCE: my delta kitchen faucet model
Is there a little rubber O-ring that may need replacing or is missing? You might try removing and flushing out the line and replacing it.
Posted on Dec 03, 2010
Replacing hose on a Kohler model numbe K- 10433
http://411plumb.com/kohler-forte-faucet-troubleshooting-repair-guide/
Mar 11, 2014 | Kohler Model 10433: FortĀ® Single-control...
Replacing pull out hose on kitchen faucet
get a hole saw that fits a drill. they come in all sorts of sizes
Jul 16, 2012 | Danze Plumbing
I can't turn faucet from one kitchen tub to other and hose is difficult to pull out
Look under your sink. The house is caught on something like your drain or something under the sink..
Jun 02, 2012 | Moen 7840 Camerist Single-Handle Kitchen...
My kitchen faucet has low water pressure both hot & cold. My faucet is a Bixby 538. I removed the spray head and the pressure is still very low. The pressure is good up to the shut off valves under...
If you have pressure to the shut off valves then most likely your shut off valves are not fully opening, I would recommend you replace both valves, they build up water deposits in them a lot of the times. The other possibility is the faucet itself has a water saver filter built into it. A lot of the new faucets have water savers built into them now.
Mar 15, 2011 | Price Pfister Plumbing
Do I have to remove the entire Delta kitchen faucet in order to replace the pullout faucet hose? If not, can you give me step by step instructions on how to replace it? Thanks.
Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
Feb 14, 2011 | Delta Faucet 470-DST Signature Diamond...
Can't get the replacement hose through kitchen faucet
you will need to undo the tap from the sink pull the tap up a little and feed the hose through the hole and connect it to the tap then re fix the tap to the sink most pull out taps are painfull to change the hoses
Jul 13, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Montuori2947@att.net
check hose to head connection ,i.e. spout.
Apr 14, 2010 | American Standard Kitchen Faucet 6310 020...
How do you repace a sprayer head on a kitchen faucet?
some models screw off at the hose.pull out the hose and look to see what kind of connection you may have,it can be easy.
Jul 21, 2009 | Hamat Richmond Pull-Out Kitchen Faucet...
Plumbing Logo
87 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
