Question about Samsung RS2534 Side by Side Refrigerator
Making a noise like a motorbike
My samsung side by side fridge started to make a noise like as if you are riding a motorbike on the freezing side of of the fridge. it stops as soom as i open the door but starts again as soon as i close the door attached to light switch. Kindly let me know what the problem could be it seems to be coming from the middle where the sensor is.
Regards
  • boydshouse Feb 11, 2009
    I have the same problem, but it seems to be on the refrigerator side. The fan putters to a stop when I open the refrigerator side.
  • 410 Answers
Sounds as if your fan motor is hitting on something most likely ice. the fan cuts off and on when the door is opened. the easist fix is to defrost the unit manually by unloading all food and unplugging the unit for several hours. if yo arent in a position to do this it will require removing coil covers to gain access to the fan and remove the ice manually. good luck peyton
Posted on Jan 28, 2009
My LG 693 LTR fridge freezer model no P247STSL is freezing the food in the fridge and building up ice in the fridge on the left side of the drawers on the wall on the side of the freezer, sometimes the fan...
The reason why fan is making loud noise is because of the ice built up on the coil because of freezing.
You can check your drain line to see if it's clogged and clean it out .
There are several video on you tube showing you how to clean drain line.
Hope this help
Jun 02, 2017 | GE PSS25SGN Side by Side Refrigerator
Refrigerator side makes noise, not getting cold
I have same fridge freezer & luckily a extended warranty, engineer has been out on numerous occasions & the motor is getting freezed up, which is why the noise stops when the door is opened. Get rid of it! No solution to the problem...its a faulty appliance & a well known fault with this model or so I have been told. Good luck.
Aug 26, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
We have a Samsung Fridge, Model SRS 598 NSS, side by side fridge and freezer. The fridge started making a loud noise when the door was opened as if the fan was coming to a halt. We had someone come out...
sounds like the motor is bad. if you have a warranty have him change it regardless if he thinks it is bad. the motor should not be noisy. If no warranty then have him check motor very good. also low refrigerant charge as well as it running too long can freeze it up and stop the fan. most refrigerators are designed to be against the wall this can be a factor in a freeze condition. I hope this helps you!
Jun 07, 2009 | Refrigerators
Water not running on Samsung RS21DCNS - why?
Water tank in bottom of fridge can freeze up if thermostat gives up. First water will stop coming out, then ice starts building up, then fan starts making noise as it brushes against ice, then fan fails, then fridge warms up  ---- all a well know scenario with this fridge. I wonder if this is the problem you have ?
Apparently Samsung are now recognizing this as a design fault and extending unit guarantee. Ring them on: 0870 726 7864  and see what happens...
Jul 07, 2008 | Samsung Refrigerators
Fridge makes howling noise
Hi there!
Check at the back for any objects or packets that are in contact with a fan. This often causes unusual noises.
See if you can identify the source of the noise, ao I can help further.
Thanks.
Jun 21, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Samsung RS263BBWP Side by Side Fridge: Water line continually freezes
higher numbers on the tempature set make the fridge
colder lower numbers make wormer
May 23, 2008 | Samsung RS2556 Side by Side Refrigerator
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Samsung RS2534 Side by Side Refrigerator Logo
138 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
