That is a software related error, You most likely need to reload the firmware, or replace the hard drive. You can try disconnecting all the document feed and scanner cables then reseating them. Other than that, your looking at a software issue.
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have...
(More)
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have checked the fuser unit and its ok. What could be the problem? Do I need a reset code to solve it and where do I get it. Please help
Job Status Completed with error(016-799) The Troubleshooting guide solution was: The print parameter...
(More)
Job Status Completed with error(016-799) The Troubleshooting guide solution was: The print parameter combination was wrong. Check the print data.
