Christie Roadrunner L6 projector has a hot spot
Has a hot spot on top of the display. Have changes lamps and reset and cleaned with no luck. What needs to be replaced? What next? Thank you!
3 Suggested Answers
  • 4234 Answers
SOURCE: turn on the roadrunner L6 the preparation display
This is an indication that either the lamp is bad or the ballast is bad. I would try a new lamp first. Also, there are air flow sensors in the lamp area that should be cleaned. If you have access to compresed nitrogen, try blowing out the entire unit to remove all dust and debris. Check to be sure that the fans are turning freely as well.
Please keep us posted.
Dan
Posted on Mar 03, 2010
SOURCE: Hi, I have a Christie RoadRunner L6 Projector.
I have a Christie RoadRunner L8 that fires up,lamps turn on and about 5 seconds after the lamps fire up it shuts down and both the warning temp. and ready lights flash at the same time. It seems to me it must be a sensor that tells it to shut down thinking that the machine is too hot-all the fans work and all of the filters are clean and it is moving serious air any clue and if so where do I start to look for such items? Thanks in advance Kirk
Posted on Sep 07, 2010
No image! My input signal is recognized, but nothing will display.
check laptop output settings my laptop uses f4 with the function key to switch the output mode your laptop may have a similar setting from Laptop only to Dual Screen to Composite screens.
Jul 08, 2015 | Christie RoadRunner L6 Multimedia...
I need a main PC board for my Christie RoadRunner 10k Projector!
Christie RoadRunner 10k ,Mainboard
USD7000,
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Nov 01, 2013 | Christie Office Equipment & Supplies
The projector tuns on fine and everything comes up alright, but the projection is not bright. I have changed bulbs and it does not seem to help. It showes that it is using both bulbs I think but the fans...
The fan that's not blowing warm air indicates that that bulb is not igniting. The best way to troubleshoot it is to switch the bulbs, just to make sure that it is not the cause of the problem. It the issue stays the same, that would be an indication that the lamp ballast is defective. However, it might just be the ballast that's causing the issue.
Aug 05, 2011 | Christie RoadRunner L6 Multimedia...
I have a Christie LX100 Projector when projecting a white image there is some yellow tint. Is this something that can be fixed?
If the yellow tint is uniformly over the whole screen then try changing the video colour tint, hue, phase and other chroma related settings in the menu.
Apr 10, 2011 | Christie RoadRunner LX100 Multimedia...
When I turn on my Christie DS30-projector, I get a message telling me that the lamp only has 10% left, even though I recently changed it. Is there a way to fix this? It clearly isn't at 10%.
You probably didn't reset the lamp timer after changing the lamp. All I could find in the user's manual is this: In the "utilities" sub menu, reset the lamp timer.
Jan 26, 2011 | Christie DS30 Multimedia Projector
Hi, I have a Christie RoadRunner L6 Projector. When I turn it on the lamp light turns red and it does nothing. This unit does have dual lamps and a lamp replacement lamp light as well. I figured if it was...
Aug 16, 2010 | Christie RoadRunner L8 Multimedia...
Turn on the roadrunner L6 the preparation display
Dan
Mar 03, 2010 | Christie RoadRunner L6 Multimedia...
Christie Roadrunner 100
check to see if the fans are moving. if not, replace the fans. if the fans don't come up, the projector shuts down to protect the circuitry and the lamp. if the fans are fine, most likely the power supply/ballast is not producing enough power to keep the lamp lit and shuts down.
Aug 14, 2008 | Christie LX45 Multimedia Projector
k24674
