Question about Zenith B32A24Z 32" TV
UNIT IS DEAD.
CX3210 AND CX3211 OBLITERATED - THESE CERAMICS SEEM TO PLACED CLOSER THAN MAY BE GOOD DESIGN -HAVE A FEELING A SPARK GAP WAS BRIDGED BETWEEN THESE TWO CAPS. BAD NEUTRAL CONNECTION FOUND AT WALL OUTLET EXACTLY WHEN PROBLEM OCCURRED - MAY BE POSSIBLE CONTRIBUTOR TO HV DISCHARGE BETWEEN CAPS ?
  • Mike Carr Jul 24, 2007
    Also found hairline crack around top of sweep transformer
  • 147 Answers
Reverse Phase Can do that on Ac expecially when the Cable is Connected,Replace both Caps and Ck the MOV also the full wave Bridge 4 Diodes and Fuse should restore Full Operation Good luck ttech
Posted on Jul 24, 2007
SOURCE:
What is gap
Hi, Mike pertaining to engine spark plugs, "GAP" is the distance between the positive and negative electrodes at the base of the plug and is measured in thousands of an inch or mm by using a round pin gap gauge or flat blade feeler gauge. Every engine manufacturer has a specific design-size-heat range- gapped spark plug. Gaps will vary depending on engine brand. Gap is also referred to in engines using a mechanical "POINTS" ignition system instead of electronic ignition (what is the points gap) for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
How to Inspect and Adjust the Spark Plug Gap NGK BOSCH CHAMPION N3 DENSO
http://www.jsesc.com/mfg_docs/ste/Spark_Plug_Application.pdf
Points and Condenser Setup wiring Setting Gap Cleaning Points Setting...
Multi Ground Spark Plugs NGK Spark Plugs Tech Video
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 12, 2016 | Motorcycles
2 of 5 burners do not start
The spark gap needs to have flow of gas across it for ignition to occur. The gas outlet holes at the point where the igniter sparks may be blocked, clean and inspect these for any blockages. Also check that the igniter spike is in the correct place. Careful evaluation of the position of the igniter in reference to the gas ring on the other rings may help you here. Good luck
Feb 02, 2008 | DCS CT-365 Gas Cooktop
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
Aug 04, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
NO start with no spark. Tried changing plug. NO change
Spark plug must be grounded against the engine to be checked. If it is truly a no/spark condition, then the next thing to check is the "dead-man" switch if it is on a pushmower and then check the ignition module air-gap. That is the distance in between the legs of the coil and the magnets in the flywheel. Different engine applications (you did not say) are set a few thousandths different but a good rule of thumb is closer is better. Set the air gap at .008"-012" or about the thickness of a standard sized business card. If this doesn't produce a spark, then the ignition module is possibly bad.
Mar 23, 2011 | Garden
I need the ignition coil gap. Got a new one and it almost started. I have a feeling that the business card may not have been the right one. Please help
The gap is set about .010-.014" The closer you can get it, the better it normally is...just don't set it so close that it is almost rubbing.
Aug 13, 2010 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Craftsman leaf blower wont start
The air gap for the ignition coil core to flywheel is adjustable on some engines and the gap does vary.
On a Stihl, I used a matchbook cover first, then doubled it and got the engine to start. That amounts to 8-10/1000ths (0.008-0.010") as measured with a digital caliper after-the-fact.
I'm troubleshooting another engine currently from a McCulloch Airstream IV that only has ~12 hours and no spark but the coil measures roughly as it should; around 1K Ohms. Was surprised to find the company went bankrupt in '99. Another one killed by Asians and fairly poor design.
May 26, 2010 | Poulan Featherlite Gas Blower, with Low...
I NEED TO KNOW THE SPARK PLUG GAP AND MAGNITO GAP FOR A POLAN CHAINSAW MODEL # 2375
Spark plug gap is .025
As for the air gap in-between the flywheel, and magneto, I generally start with a piece of notebook paper in-between them.
After the bolts are snugged down, turn the flywheel by hand to spin the paper out.
Oct 29, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need to know the value for Capacitor CX3211 on the edge of the board. The CX3212 next to it reads HR R 561K 2KV and I wonder if they are the same. THe CX3211 burned and the TV died. I am layed off and...
The value of CX3211 is 1000pF 10% 2000V, ceramic disc.
You can also download the service manual from this website. Make sure to download all the 7 files.
Good Luck.
Jul 26, 2009 | Zenith B27A11Z 27" TV
UNIT IS DEAD.
believe are the two caps., beside the large H.V. transformer? Just replace the two capacitors and should be fine, I have this problem before. Now as far as open neutral there maybe other damage to the set.
Nov 22, 2007 | Zenith Z27A11G 27" TV
Need capacitor specs
please check scmematicas given in web as shown& find the value http://www.eserviceinfo.com/downloadsm/20265/_SAR%202953%20BT.html
Sep 29, 2007 | Zenith B32A24Z 32" TV
Zenith B32A24Z 32" TV Logo
102 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
