Question about Olympus SP-510 UZ Digital Camera
Photo won't delete on olympus SP-510UZ camera
I think I may have accidently locked an image that I actually want to delete how can I remove the image
I removed the memory card, put into card reader and deleted the image that way.
Posted on Jan 29, 2009
I have an olympus sp 800uz camera and my computer won't recognise it to download photos
1. You might be able to download foto's from the camera, when you do it manually from within the installed Olympus program. Windows XP has problems with auto downloading foto's from ib.
2. Otherwise, check if the computer is recognizing the camera (see LCD) and with the Explorer if a removeable memory device is available from the camera.
3. Try putting the camera into another USB port, or try the camera on another computer.
4. As an alternative, you might want to install a better and also free Olympus program:
http://support.olympus-imaging.com/ov2download/index/?Lang=ENU
Jun 30, 2011 | Olympus SP800UZ Digital Camera
Camera Olympus SP- 510UZ: while turning the machine at the screen appears "card setup", has 2 options "power off " and "format". I want to see the photos and is not possible....
remove the card and place it in a regular computer card reader. most Olympus used to use XD so if yours is XD make sure the card reader supports it. Otherwise it wil be an SD that most readers can handle.
Copy your pictures off the card and whilst it is still in the computer FORMAT it using FAT or FAT32
Once bak in the camera it should be good to use again.
If Not then the card has a fault and you mayneed to replace it.
Feb 15, 2011 | Olympus Cameras
Tried to install new camera but it has not brought up the users manual or IB programme. I can upload photos to the Olympus master programme.
The Olympus SP-800uz users manual can also be downloaded:
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1499
or English:
http://www.olympusamerica.com/files/oima_cckb/SP-800UZ_Instruction_Manual_EN.pdf
The Olympus [ib] software is on the cameras internal memory, if you did not format (delete) it. Look there for the setup.exe and run it. Although the best alternative free Olympus software is Olympus viewer 2 which replaces also Olympus Master 2:
Dec 28, 2010 | Olympus SP800UZ Digital Camera
Have lost instruction! How do I download photos from my Olympus SP-510UZ camera to disc. Barry
Here is the link to your camera where the manual is located.
http://www.olympusamerica.com/CPG_SECTION/cpg_support_product.asp?id=1268
Load the software, connect the usb from the camera to the computer, by using the software download it to your computer and use Roxio, Nero, etc software to burn pictures to your cd.
If it has a slot for SD card you can directly burn it from the SD card to the CD player if you have media card slot on your computer.
Sep 19, 2010 | Car Audio & Video
Blue bar on right hand of screen
I think the problem you have is that the shutter speed is too fast. make the shutter speed slower and try taking photos.
May 31, 2009 | Olympus SP-510 UZ Digital Camera
Olympus sp-500 uz can I get the date on a photo
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Apr 05, 2009 | Olympus SP-500 UZ Digital Camera
Accidently deleted all photos from camera w. memory card still in
As long as the xD card was not formatted it is possible to recover the images that were accidently erased. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering lost images.
Data recovery is a booming industry, and many appropriate services and software can be found by searching regional phone and business directories or the Internet for terms such as "image recovery" or "data recovery".
Mar 22, 2009 | Olympus SP-550 UZ Digital Camera
Green key shows on screen, cannot delete that photo
The key means that the picture is locked so you can not erase by accident. You need to remove the key be for you can erase the pic. If you have the manual it will tell you how. if not get me the model of camera and I will get you a manual.
Jan 18, 2009 | Olympus FE-220 Digital Camera
Olympus sp-510uz, power went down and new batteries,
you may gently try to push the lens in, but if you are under 1 yr warranty... i would send to repair
Dec 16, 2008 | Olympus SP-510 UZ Digital Camera
Ahhhhhhhhhhh
Try to format the memory card and permanently delete all data from the image card. Go to menu to setup and then to format option. The card should then be back to being able to store its maximum number of images depending on what size card it is.
Jun 24, 2008 | Olympus SP-510 UZ Digital Camera
Olympus SP-510 UZ Digital Camera Logo
85 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
