Question about KitchenAid KT2651X Epicurean Stand Mixer
My kitchenaid shut off while i was mixing with it.
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
I have a new kitchenaid mixer and both times i've used it the cake did'nt come out right, it was bland and it fell apart and that never happened before. what did I do wrong?
It could be that your over mixing the batter. It is very easy with a KitchenAid to push a batter too far, and you get too much air, or cream the butter too much into the flour, or press all the oil out of peanut butter. Try using the mixer for only as much to get the matter mixed.
Jul 03, 2012 | KitchenAid Food Mixers
My kg25h7x varies the mixing speed on its own
The Kitchenaid uses a centrifugal switch to maintain a constant speed. This must be sticking to cause this. You mixer will need to be disassembled and inspected.
Jul 03, 2012 | KitchenAid K45SS Classic Stand Mixer
When I turn on my Kitchenaid mixer at any speed, it ramps up to high speed and then shuts down after maybe 30 seconds.
You need a reputable repairman. My gears were stripped after trying to mix a very thick dough. It would only work on high speed. After it was repaired.... I still use it, all the speeds work, and that has been 15 years ago. My mixer was at least 8 years old at the time of the "stripping".
Aug 21, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
The mixing part of mixer not working motor is fine
Hi. Since I can't tell how much you have taken apart, I'll start from the beginning.
Remove the silver band, remove the top cover. At the top front of the mixer locate the transmission housing. If it's plastic, inspect it carefully for cracks around the screws and the body of this housing. If you find cracks, you have found the cheap plastic part that kitchenaid still installs in new mixers, and the cause of your trouble. They know that it's substandard but don't care enough to place a recall notice on this part. It may not please you to know that their replacement part is METAL like the original part should have been. "For the way it's made"! Indeed!
If you intend to repair the mixer yourself, go to kitchenaid's website, enter your model # and locate the parts list for your mixer. Download the drawings, they will assist you with your project.
Be sure to tell kitchenaid what you think of their cheap plastic part.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 12, 2009 | KitchenAid KP2671 Professional 6 Series...
Bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Mar 28, 2009 | KitchenAid K5SS Heavy Duty Commercial...
MIxer quit working while mixing 3 batches of oatmeal cookies
Hi. Kitchenaid's warranty is 1 year.
Most likely, the plastic transmission housing has failed, causing damage to the working parts inside your mixer. Take it to a local repair place and have them work up a quote to repair it. It will take at least a month to get the parts.
If this solution has assisted you, please rate it. ricardok45
I
Dec 06, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
KitchenAid KT2651X Epicurean Stand Mixer Logo
22 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
