Home | Honeywell | Power Humidifier: Furnace Humidifier/ Hum... | Honeywell TrueSteam Hum...
Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Problem for Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Honeywell TrueSteam Humidifier - I have 2 - one keeps flushing
By dorteg on Jan 28, 2009
If anyone can help me, that would be greatly appreciated!
I have 2 Honeywell TrueSteam humidifiers - 1st for upstairs and 2nd for downstairs. Although both seems to keep running as of late, the 1st one for upstairs I noticed keeps "flushing" condensation or the water contents itself onto my condensate pump. The drain hose seems to be always very warm or hot. While the 2nd hose seems like it is always cold. I've observed this for the past 3 days - every few hours I would check since 4 days ago, there was a leak in my basement from condensate pump (related but different issue).
I read in the manual that it would only flush every 10, 20 or 30 hours of continuous use unless you manually press "flush." It seems that this is the case for the 2nd one, but the 1st one seems to be constantly flushing.
Is there something wrong with the 1st one? Will it go bad quicker since it's constantly flushing?
Any help would be very much appreciated!
Thank you,
Duane.
Same Problem
Apr 15, 2009
-   I have the same problem and am wondering if it is an inherent defect with these units. I have had a truesteam 6 gallon and a 12 gallon and now both of them have worked for a few weeks and both went into the constant 24/7 draining (while it humidifies or not) that is completely independant of the auto flush cycles.-   bradwr
Solution #1
posted on Mar 25, 2009
Not Rated)
andersaj
Rank: Apprentice
Rating: 0%, 0 votes
I also have 2 Honeywell TrueSteam humidifiers and had the same problem; both were operating, but one was always flushing. I took the one apart and found a lot of scale on the water level sensor assembly. I just finished cleaning it off and now it seems to be fine. It looks like the sensor was allowing too much water in and then it had to be pumped out. Worth a try.
Was this helpful?
Yes
No
Solution #2
posted on Feb 03, 2009
Not Rated)
wildhawgz
Rank: Guide
Rating: 0%, 0 votes
Check the dip switches (located under the cover) for the auto flush settings make sure unit is unplugged and cool first
Was this helpful?
Yes
No
Solution #3
posted on Jan 29, 2009
Not Rated)
kim264
Rank: Master
Rating: 87%, 10 votes
don't know if this will help or not but dip switch 1 and 2 control the flush cycle on this unit. double check how they are set. the setting for flushing every 5 hours is not listed in the manual, but if both 1 and 2 are in the on position it will flush every 5 hours. hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Honeywell Power Humidifier:
Questions and Unsolved Problems for Honeywell Power Humidifier:
Do you recommend Honeywell Power Humidifier: Furnace Humidifier/ Humidifier?
Answer
Answer
"replace better" msg light came on; I replaced with 3 AAA Alkalines...3 days later, same... (More)
Answer
Mod#BLU100K948A The 2 selenoids on top of gas valve click when they open (normal). Sometimes they... (More)
Answer
I am trying to wire a honeywell true steam humidifier for a honeywell zone system
Answer
wait 5000 humidifier will not cycle on even when i use a hair dryer to blow hot air
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Honeywell Power Humidifier:...:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
