6th Sense Washing Machine - No water coming through plus...
Problem, I am in France adn can get no one to take me seriously about problem.
Hydro senstive light comes on, water only shoots in for nano-second. Noise in machine, like a pump trying to work, which still continues when I turn off the machine. Only stops when I pull out the plug.
Had same problem in December, guy came out, could find nothing. Annoyed with me for wasting his time, 'very French!'.
Machine outside, maybe I should bring it into the house, but it is a huge 10kg machine!
Maybe too cold for pipes, is there a too cold switch off. F and A are illuminating.
Desperate!
Thanks
    Genius:
  • 2,920 Answers
You may want to move it into the house where its warmer.if the hoses are getting too cold it wont allow the water to get into the machine. move it to the house..
Posted on Jan 28, 2009
My whirlpool 6th sense front loader has stopped whilst full of water, half way through a wash. Have emptied machine, Still no power, machine wont turn on.
Hello Janine Gooch,
Went out on our internet trying to find your trouble shooting guide (typically in the OWNERS MANUAL)...
Finally ended up in AU ... No luck.
(September 9th is only 6 hours old here (SF Bay area)).
Your local peers have NOTHING NICE to say about that machine... particularly the CONTROL BOARD:
Whirlpool WFS1071BD Question and Answers
Hope this helps (says top load... shows front)
Carnac the Magnificent
Sep 09, 2017 | Whirlpool Washing Machines
I get ESC error problum how to solve them
No water is detected having entered the machine. Check your water lines, make sure they're turned on and feeding water to the machine. If they are then you may have bad sensors in the washing machine. The ESC error occurs when no water is detected as having entered the machine. The Washing Machine upon not detecting water turns off the internal valves and kicks the error.
Jul 31, 2014 | Whirlpool Washing Machines
Whirlpool 6th sense washing machine
All washing machines have a water level sensor, this can be a tube into the drum that leads up to a switch normally attached to the inside higher up, what happens is the tube gets clogged up with muck and gives a false reading, which needs cleaning out.
Another problem may be your input valve normally a sngle cold water input, the valve can get clogged with limescale and its just slow to switch off even when the power is off. The default is a closed position.
Try switching the machine off at the plug as soon as it finishes, if it starts filling up its the input valve, these can be under twenty pounds on popular auction websites.
May 11, 2014 | Whirlpool Washing Machines
HI, WE'VE GOT A WHIRLPOOL 6TH SENSE WASHING
washers are very expensive to fix they cost more to fix then to buy
Aug 09, 2013 | Whirlpool Washing Machines
Its a whirlpool 6th sense washing machine no awd/d 5706, it stopped with a full load in 8 minutes before end time no numbers are flashing up but it wont do anything , i have opened the door took washing...
i have a whirpool 6th sense washing machine and it wont spin and the timer stays on 14 minutes remaining have you come across this problem and do you have a cure
Jul 29, 2010 | Whirlpool Washing Machines
I have a Wirlpool 6th sense washing machine. Every wash water leaks from the soap tray. Is this a common problem and easy to fix?
It should not leak, pull the drawer out there may be a build up of soap powder causing the water to come out the front.
Apr 18, 2010 | Washing Machines
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
Whirlpool 6th sense washing machine doesn't go into high spin
sounds like you have a blocked hose/pump vent hole.......if its holding water in the bottom of the tub it wont spin it will try but the pcb wont let it do the spin .due to pressure switch telling its got water left... pull pipe off pressure switch check holes not blocked check all hoses......
Dec 30, 2009 | Washing Machines
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
