Question about LG WM0742HGA Front-Load Steam Washer with 4.2 cu. ft. Capacity, 9 Wash Programs, 6 Temperature Levels, Spin Speed of 1,200 RPMs, Allergiene Cycand Rear Controls, 27, Pearl Grey Color, ChiLock, SeDiagnosis, Auto Balancing, Auto Sud RemovaForced Drain Sys
Clothes are dingy after several months use I use GainHE why is this happening?
I have never experienced this problem with other washers and have used Gain for years. I have white towels and even used bleach and this did not help.
  • LG Master
  • 17,130 Answers
I think what is required is to clean the machine well , use a good cleaning solution and also vinegar with a hot water washing.
Please click this link for tips: Washing machine maintenance
Posted on Jan 24, 2013
SOURCE: Water left in bleach tray as well as bleach
There are multiple soleoid valves which run water through this tray. The valve connected to the bleach compartment is not functioning properly.
You can see these valves on back top of machine after raising the lid.
More info, let me know.
Charlie
Posted on Aug 30, 2009
VtToolMan
  • 704 Answers
SOURCE: Smelly clothes, nasty towels. Temporary solution.
This can happen with any front loading washer, regardless of the manufacturer.
One of the first things to do is make sure you're using the He (High efficiency) laundry detergent and only use a small amount, about 3 tablespoons or less. The trick is to not use so much detergent that you start getting a buildup in your machine. Also, if you have heavily soiled clothes, pre-treat them instead of adding more detergent to your wash cycle. This alone will result in better results.
Also, be certain the washer is properly leveled in all directions and to make some slight changes in your wash day schedule.
By making sure the washer is properly leveled, it will operate better and help minimize odors, as the spin cycle will get more water out, etc.
The other tip, that has really helped in our house, is to do all the hot water (whites) as the last load. Since we do use bleach when we wash our whites, along with hot water, the washer's last load will have had the best sanitizing cycle run through it before being left for the next load another day.
With the bleach and hot water, the washer gets a nice clean disinfecting wash which helps eliminate odors, germs, excessive soap, etc. and leaves the washer fresher. By doing this, we don't have to purchase other (more costs and expense) additives to run through the washer to attack the odor causing germs and gunk.
What good is a more energy efficient washer if I have to always run a special tablet/liquid cleaner in it each week without any laundry in that wash load? Seems wasteful to me to be doing an "extra" wash just to wash the washer. So I'm not a proponent of having to always use another product every week or month to have a washer work like it should.
However, if you've got an existing (smelly/moldy) washer presently, I would recommend that you use a produce called Whirl-Out, which will help dissolve the buildup that your machine currently has and get it clean again. Then you can follow the steps above to keep it from causing you issues in the future.
I hope you find this Very Helpful and best regards!
Posted on Sep 21, 2009
  • 534 Answers
SOURCE: I have never liked my lg and now it seems that
You might check the water inlet valve on the back of the machine where the water hooks up. There should be a blue plastic water valve. remove the water hose on both sides hot and cold. At the blue water inlet valve inside the connector there are small filtering screens (similar to an areator valve on your sink faucet) They may be clogged by sediment and this would cause your low water issue and possibly the smell. Simply pull out the screens with a pair of needle nosed pliers and replace. Hope this helped
Dave
Posted on Nov 05, 2009
  • 255 Answers
SOURCE: my white clothes are coming out dingy and gey from
I have an LG front load washer too and sometimes my whites don't come out as nicely as they should. Usually draining the machine and running several cleaning cycles solves the problem. I hope it works for you!
Posted on Jan 08, 2010
  • 161 Answers
SOURCE: I am so disappointed with my washer i was pleased
Do you have any error codes? It sounds like a heat problem but, if the heater is bad you should have a code displaying.
Posted on Jan 27, 2010
Why are my clothes dark and dingy?
Pat, All I can suggest is for you to try a different detergent. The links below make some suggestions that may help brighten and clean clothes better.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solutions for Dingy Clothing
Having Laundry Issues It Probably Not Your Washer Fault
Help With Clothes That Look Dirty From an HE Top Load Washer
May 07, 2016 | Dryers
Washer not washing leaving stains on clothing
It sounds like the silicone apron between your washer drum and the door has deteriorated. If that is the case, no cleaner will help you.
Best solution is to order a new one.
Jul 31, 2010 | LG WM2455 Front Load Washer
Is there any way to make white clothes less dingy when using an H.E. washer such as the Kenmore Elite? I've tried cleaning the washer once a month, using a little OxiClean with the detergent, using bleach...
Try nappysan. As you have found out bleach is no good. In the "day" we used to use a "Bluing" Agent, see if you can get those, My solution is to use just a dot or 2 of Dawn dish washing liquid on any spots I thought would stain-scrub them for just a minute with a fingernail brush. Then I would fill my washer about 1/4 of the way with straight hot water & add a 1/2 c. of automatic dishwasher soap to the tub--the cheaper the better because most cheaper brands have more phosphorous. I'd swish the water around, turn the temp. to warm, & put in my whites when the tub was about halfway full. Then I'd add about half the amount of detergent to the tub that I would normally use.
Apr 20, 2010 | Kenmore Elite 45986 Front Load Washer
My white clothes are coming out dingy and gey from my LG front load washer
Jan 08, 2010 | LG WM1814CW Front Load Washer
Dingy Clothes
What is the answer for dingy clothes? I have the same problems and I'm getting ready to get rid of this washer because I'm tired of not getting clean clothes and having my towels smelly after taking them out of the washer.
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have an Amana ALW880QAW that is putting yellow spots on the clothes.
possible you have older machine with rust in the tub
broader spots to allout dingy colors if clothes set in washer
or have well water ...that can make a difference
Aug 24, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Dingy whites
smaller loads - so articles arent drawn to the hole.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I live in the country in NC. My water is well
For brighter, softer, stain-free clothes, add 1/2 cup Arm and Hammer® baking soda to your regular detergent in the wash cycle, then add 3/4 cup Heinz® white vinegar to the rinse. Soak really dingy clothes for ten minutes in the baking soda-detergent mix before washing in the hottest water fabric will accept. Vinegar smells should vanish after clothes have dried. Many online voters said that this worked best.
Jun 30, 2009 | Fisher and Paykel GWL11 Top Load Washer
Also can't get whites clean in out front load washer
try using a bit of automatic dish soap in with the detergent and bleach .Ifound that to do wonders
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
LG washer (WM0532HW) whites turning dingy grey
I too have a front load washer. The problem is that it's not washing off all the soap suds. Try this. After a complete cycle, soak the clean clothes in a container w/ water and you'll see there's still soap suds coming out of the clothes. I tried running it several wash cycles and there was still soap left on the clothes. I think, it's mfg defect. We should all complain to the maker of the machines.
Jul 25, 2008 | Washing Machines
LG WM0742HGA Front-Load Steam Washer with 4.2 cu. ft. Capacity, 9 Wash Programs, 6 Temperature Levels, Spin Speed of 1,200 RPMs, Allergiene Cycand Rear Controls, 27, Pearl Grey Color, ChiLock, SeDiagnosis, Auto Balancing, Auto Sud RemovaForced Drain Sys Logo
78 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
