Question about Epson Stylus C46 InkJet Printer
PAPER JAM HP PHPTO SMART 2710
HOW DO I GET TO PAPER JAM TO REMOVE
  • 684 Answers
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer........ Still have the Same Problem.... Check for any foreign objects stuck inside the Printer............If Not...... Call HP at: 800-588-3554 And get the Printer Replaced
Posted on Jan 28, 2009
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
Tip
My 2710 All In One keeps giving an error message that the printer cartridges are...
Is your cartridge clogged,,,
Then in the maintenance settings in PRINTERS AND FAXES,, do a deep ink cleaning,,
If that fails then blot the cartridge on a piece of tissue damped with alcohol.. or let the cartridge sit in some rubbing alcohol for a cpl or minutes and then blot it..
As a last resort if the above fails,,, WARNING NOT A CONVENTIONAL METHOD
try boiling the cartridge for a few minutes,, MAKE SURE THE WATER IS BOILING BEFORE U PUT THE CARTRIDGE in.. so to to remove most of the air from the water to prevent corrosion
on Dec 28, 2008 | Canon PIXMA MP150 All-In-One InkJet...
My HP photosmart 2710 all-in-one has "spot sensor
The Spot Sensor Out of Calibration error comes due to color paper placed in paper tray.
Follow the steps to resolve this issue.
1. Under printing preferences set the paper type to plain paper instead of automatic. This makes it so that the spot sensor doesn't need to look at the paper.
2. The spot sensor, when calibrating, needs plain white paper. Setting the plain paper instead of automatic helps if you are just printing, but colored paper makes the spot sensor confused during calibration.
If you are still not able to print, there is a utility program that fixes the issue too and which will be helpful for you in future use too. Click on the link to download the utility program : Utility download
Hope this resolves the issue.
Nov 04, 2010 | HP Photosmart 2710 All-In-One InkJet...
I have a hp photo smart 2710 THE PRINTER IS TAKING MORE THAN ONE SHEET AT A TIME
clean the paper feed roller. also fan the paper before you put in the tray. there is a seperation pad as well. clean it and try again.
Oct 01, 2010 | HP Photosmart 2710 All-In-One InkJet...
Paper jam problem
Just unplug the power cord and open the cover and remove the cartridges and manually try to roll the roller and slowly try to pull the paper.
Jan 28, 2010 | HP Photosmart C6280 Printer
Won't turn on
When removing jammed paper from a printer you need to be very careful as printers have a paper sensor which is very sensitive and it can be damaged if you pull the paper to hard. I first need to know, the printer doe not turn on or it does not print ? What brand of computer is it ?
Aug 25, 2009 | HP Photosmart 2710 All-In-One InkJet...
Carriage Jam Error Message
Carriage jam error happens when either the clean station is gummed up and not moving toward the rear properly, or when the encoder strip gets covered with ink or grease. The strip you can clean with water and a Q-tip, the clean station can be cleaned with water, but you have to take the covers off to get to it.
Aug 07, 2009 | HP Photosmart 2710 All-In-One InkJet...
I have a HP Photosmart 2710 All in One with jammed paper.
The only option is to open up your printer to get access .....try using tweezers to pick on it and slowly removing....
Nov 10, 2008 | HP Photosmart 2710 All-In-One InkJet...
Carriage Jam error always - how do I fix it?
Try resetting the printer (pressing the cancel button and connecting the power supply, check in the HP website if this is correct for your printer model) , after the reset the printer will clear any errors and will recalibrate the mechanism including the paper feed mechanism and the carriage.
Also check if the carriage is moving freely by disconnecting the power and moving it by hand.
Jan 21, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2710 (Wireless)
Introduction
The flashing error code that indicates a jammed printer is the digital-age equivalent of a
flat tire. Sooner or later it happens to everyone, so you'd better know how to get things
moving again if you want to finish your print job.
Instructions
Difficulty: Moderate Steps
1 Step One Turn the printer off and on to see if it can automatically clear some or all of
the jam. Many printers provide an error-code listing on the front panel display for the area
where the jam occurred. If your printer shows an error code, be sure and check the printer
manual to see if that identifies the area of the printer where the jam occurred.
2Step Two Turn off the printer.
3Step Three Remove any paper trays. Inspect them for wrinkled or damaged paper.
4Step Four Open any other doors that give access to the printer's paper path and to the
toner or ink cartridge.
5Step Five If necessary, remove the toner or ink cartridge. Place it in a bag or away from
light to avoid damaging it.
6Step Six Click to enlargeIf you find a piece of jammed paper, remove it by holding it with
both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If
several pieces are jammed together, try pulling out the middle piece first to loosen the
jam. SEE PICS http://www.imagehost.ro/pict/0104361047293b9a4006c.jpg
7Step Seven Click to enlargeIf the paper does tear, try rotating the roller gears manually
to free the paper (see B). Don't force anything, though.SEE PICS
http://www.imagehost.ro/pict/0104365847293bcaa9870.jpg
8Step Eight Replace the toner or ink cartridge and paper trays, close any doors you opened
and turn the printer back on.
9Step Nine If the printer paper jam message still appears, then there is still some paper in
the printer.
 Reinspect the paper path.
Oct 31, 2007 | HP Photosmart 2710 All-In-One InkJet...
Epson Stylus C46 InkJet Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
