Question about Air Tools & Compressors
I have a proforce vpp0200604 air comprssor what oil does it take
4 Suggested Answers
  • 98 Answers
SOURCE: need a unloader valve for a ProForce model no.
Need to know the desired pressure for your compressor, please dont exceed the compressors capabilities
Posted on Jul 21, 2009
harlan301
  • 205 Answers
SOURCE: i need a part for VPP0200604 PRoforce air
that made by powermate which is out of business no part. you can check with pramc co which owens that division know. 800-445-2276
Posted on Oct 14, 2009
nampaboat
  • 150 Answers
SOURCE: I broke the wheel on my Proforce (VPP0200604) air
The wheel kit has been discontinued so I would go to http://www.mastertoolrepair.com/advanced_search_result.php?keywords=wheel&x=23&y=9 and see if you can match one up.
Posted on Mar 13, 2011
Need piston rod for rep0200604 compressor
A search of your model number turns up a powermate compressor. Unfortunately the piston rod is not available as a seperate part, you have to order the entire pump/motor unit. The only place I could find it was at this link: http://www.ereplacementparts.com/powermate-vpp0200604-single-stage-oil-lubricated-air-compressor-parts-c-117046_117047_117049.html.
Dec 23, 2010 | Coleman Proforce 6 Gallon Air Compressor
I have a proforce 2500 watt generator and it cuts out is this caused by low oil? if I change oil how much does it get?
Low oil doesn't usually make engines cut out. Clean the air filter, change the plug and wire. If this doesn't help then I think you're looking at a carb. problem. Probably just clogged jets & ports. It's very common on small engine carbs. It shouldn't take more than 2 quarts of oil. Probably not even one.
Nov 30, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
Will not fill with air where can I get parts?
Below is a link for parts to a Coleman compressor model #VPP0200604. Not positive but I think that is what you have.
However before you buy anything how do you know what the problem is? Is the motor running? If the problem is that it's just worn out you may find it difficult to get parts for rebuilding it. What you have is whats commonly referred to as a throw away pump. The second link show the pumps replacement cost, around $85.00. If you do manage to get rebuild parts for it they will cost at least that much.
You can get a Senco at Home Depot which is a couple grades up from yours for around $125.00.
Your compressor is really not worth the effort to rebuild it.
If on the other hand your compressors motor is not starting up please include any details in a response to this and I'll try and troubleshoot it for you.
Hope this helps.
http://www.mastertoolrepair.com/vpp0200604-vp0200604-p-14827.html
http://salestores.com/colema14.html
Nov 16, 2009 | Coleman Proforce 6 Gallon Air Compressor
I need a part for VPP0200604 PRoforce air compressor
Oct 14, 2009 | Coleman Proforce 6 Gallon Air Compressor
Need a unloader valve for a ProForce model no. vpp0200604 air compreesor
Jul 13, 2009 | Air Tools & Compressors
Broken Part. Need Replacement
If you refer to the oil filler plug, item #6 in the diagram linked here, it's listed as obsolete.
If refer to the intake filter, It's item #3 on the diagram, it too is listed obsolete.
I would contact Master Tool Repair at 757-410-2879. They can cross the part to another once they know the thread size of the old part.
Mar 15, 2009 | Coleman Proforce 6 Gallon Air Compressor
Comprssor hard to turn when cold
yes in winter you should use thinner oil ~~15sae
Jan 29, 2009 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
