Question about Briggs & Stratton Garden
Countax won't start.battery full no dashboard light when key turned
4 Suggested Answers
jim4984
  • 797 Answers
SOURCE: Re: Huskee MTD lawn tractor
Most tractor have an inline fuse coming off the relay (small box where the positive lead connects from the battery). If you have a multimeter or trouble light, check both sides of the wire that comes off this box to ground. With the switch on, you should have voltage to both sides of the wire. Voltage to only 1 side would indicate the inline fuse is bad. There may also be a fuse box. My craftsman uses both the inline and fuse box.
I tried getting the manual for your tractor but .... they want the serial number in addition to the model number. You can download the manual from here, but need the serial number when you go to get it.
Good luck, Jim
Posted on May 31, 2011
  • 640 Answers
SOURCE: have a john deere sabre
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Posted on Aug 07, 2011
  • 640 Answers
SOURCE: TURN KEY WON'T START BYPASS SELINOID IT
There are a few things it could be. You need to do a check of the coil, safety switches and the ignition switch. You can check the starting solinoid (coil) by jumping from the hot terminal on the main contacts to the terminal that gets its power from the ignition switch (caution, do not go to the ground terminal if it is a four wire solinoid) . If it turns the engine, then you need to check the ignition switch. This is easier with an electrical multimeter. Remember to check the safeties. I have observed that the seat safety switch is the most common electrical component to fail.
I hope this helps.
Posted on Sep 02, 2011
Mazda Tribute won't start and has no electricity
This is a common problem with Mazda tribute and Ford escape. Replace the ignition switch. Actually, if you close the doors and turn everything off. Insert key and turn to on position, do not start, verify all dashboard lights come on. If they are, just press key in and jiggle around a bit, then try starting, u may have to do it a couple of times to start it. But, change the switch and possibly the key tumbler..do switch first and test. .then key tumbler if not successful. Both parts should cost less than $80..good luck.
P.S. you can replace the switch yourself, remove steering column 4 screws, switch has a yellow or white markings and is on the left of the column opposite the key side.
Oct 27, 2017 | 2004 Mazda Tribute
My mitsubishi galant suddenly won't start
1. Check n clean battery cables with a battery brush. Look at both ends, if able.
2. Check battery acid level. Add if needed, get a jump.
3. All OK? Then get a battery load-test done free at a parts store.
18 degrees in September? Isn't that Celsius?
Sep 28, 2017 | 2001 Mitsubishi Galant
My remote didn't open doors, on my1998 Saab 900S, so I used key to unlock manually. The alarm went off, and car won't start. When I open the door the anti theft alarm goes off again. This is E
Replace the battery in the remote, then reset the system.
Resetting a Vehicle Anti-Theft System
This is how you reset an anti theft system if you have the anti-theft light on, or your car is cranking, but you have no spark.
Doing a full reset of the anti-theft system.
Disconnect both battery leads for at least two hours.
Hold the negative and positive leads together for 5 minutes to fully discharge any power.
Put the key in the ignition, but not turned on. VERY IMPORTANT!
Connect the positive lead.
Connect the negative lead in one swift movement.
Wait 15 minutes for the system to fully reset.
Resetting Vehicle Anti Theft System
Mar 06, 2018 | 1998 Saab 900 S
My 2000 Vespa et150 won't start. Battery is fully
-do you use the right key? (thick brown/black colored) after aou turn the key on, does a light go on on the dashboard?
- seems to be an issue with the lock code of the key (wrong key)
then the engine immobiliser does not allow to start..
Sep 17, 2012 | Cars & Trucks
Ford fusion stuck in park, engine won't start
It sounds like you have a dead battery. have it tested.
May 30, 2012 | 2007 Ford Fusion V6
Hello I have a problem with my Pontiac 2002 Trans Am - Collector Edition. It does not want any more to start, there is the indicator SECURTITY which east lights, and since average making it...
Check the battery voltage with a multimeter. If the battery can't deliver a full 12 volts, the starter solenoid won't even activate. It may be that a cell went dead, causing a direct short inside the battery. Replace the battery if your battery is older than 3 years, or take it to an auto parts store to have it tested. The security light on is an issue many people have when the battery is low and the car won't start.
It is also possible that the security chip on the ignition key is worn. If it isn't making contact properly, the computer won't 'read' the resistor, and won't start. You will need to replace the key to see if this fixes the problem.
Aug 17, 2011 | 2002 Pontiac Firebird
Hi, I tried starting my Chevy Impala 05 today and it won't start. My car was not locked from the previous day I drove it to the city. But today I opened my car and my alarm goes off and won't...
put the fuse back in and try this,, when the alarm goes off, try holding down the Lock and unlock buttons at the same time, that should reset your alarm
Jul 29, 2011 | 2005 Chevrolet Impala
Dear sirs, I have a 2000 Ford Explorer which won't start. All light in the dashboard turn on but the engine won't crank. We've tried to crank the engine direct from the battery and it cranked....
yea got get you more troubles
just check the alternator is charging well and no battery light on dashboard it indicate the bad alternator
monitor your battery if it got old and cannot hold the charge any more
you said when you used another one your car turned on
Jun 06, 2011 | 2000 Ford Explorer
It won't start up and when i turn the key, it makes no noise, just all the lights turn up on the dashboard!! I need tips how to fix it!
It sounds as if the battery is almost without a charge. The lights will work in this case but there is not enough power to turn the starter. Can you obtain a jump from another car? If the battery is too low, the jump might not work. Remove the battery abd have it tested at Autozone or another auto parts store.
May 15, 2011 | 2004 Jeep Grand Cherokee
Garden Logo
104 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
