Question about Nokia N73 Cellular Phone
I cant read new masseg......
Hi i am vikas from gujarat,
i have nokia N73 phone.i am having masseg that says youhave full mamory delet some data.i cant read even new masseg.i have chosen mamory card for the masseg,but still i m having same problem.now wat shouldido?????
Hi
You have to delete some of your large files on your phone such as photographs, etc and then it will be fine.
Posted on Jan 29, 2009
Phone mamory full on nokia N76
Hi There
U might need to use Nokia Suite Pc.Nokia PC Suite is a software program that allows you to manage and move content between any computer and phone that runs a Microsoft Windows operating system. One great feature of this program is that you can backup your phone's data onto it. Whether you just replaced your old Nokia phone with a new one or you just did a factory reset, you can get back your old data and settings quickly if you properly backed them up with Nokia PC Suite.
refer here to backup your phone.
OR U MAY TRY THIS AS SECOND OPTION.
This is a trick for completly format your symbian phones.it specialy usful for those who wants to remove virus from mobile phones. Now here is three methods to format your phone. choose 1 method wich is simple for you..
complete format nokia symbian phones
Important Note:- Before step to this process make sure you have copied all your contacts and notes onto your Memory, because every thing will be deleted. When its finished the formatted phone may be like new, just like when u have brought it from showroom.
This trick works almost all Nokia symbian models. Example n-series,/s60v3, s60v2(N73,N78,N95,N70,N81..etc) and s60 models.
Method 1 hard format
1. Switch off your phone
2. Remove sim card & memory card
3. Now press & hold keys ( 3,*,call green )
4. Then holding these three buttons the press power button
5. Formatting task will be started
6. key *, 3 , call (green) press and hold when display is on than formatting screen is displayed. Wait for formatting to be finished
Method 2
1. Press following key sequence *#7370#
2. It will ask you to confirm press yes
3. Enter Default lock code 12345(defoult by nokia) note <---if you have changed your code type your code not defoult
4. And your phone will be restored in defoult factory setting
Method 3 soft format
1. Press following key sequence *#7780#
3. Enter Default lock code 12345(defoult by nokia) note <---if you have changed your code type your code not defoult.
TQ
Oct 25, 2017 | Nokia Cell Phones
Hi,i have an nokia n73 and i cant send and received mesage beaucause on the screen apears memory full erase data first,i erase allmost all the data from phone and this problem continous.
Back up your contacts to your sim and do a hard reset by dialing the following keys. *#7370#
That will restore eveything but BE SURE TO BACK UP ANY DATA YOU NEED BEFOREHAND as everything will be wiped and reset.
Feb 28, 2011 | Nokia N73 Cellular Phone
My phone shows memory low, delete some data, my phone memory is full with 44mb & free space is170kb, cant receive any messages also
In ur Phone memory only 170 kb is free . so, delete some data in phone memory or change datas to the memory card. Then u can receive messages
Aug 28, 2010 | Nokia N73 Cellular Phone
My phone is always in offline mode though i changed the profile settings many times. also, my phone always says "memory full. delete data first" though i tried doing *#7370#..it only restored the original...
memory full , remove ur mmc 1st then *#7370# format again, test the phone with out mmc, post result
offline mode mean no sim card detect, try other sim card post result
if cant u need flash the phone with new firmware
Jun 08, 2010 | Nokia N73 Cellular Phone
My N73 says Memory full delete some data. please help
simple solution... just delete some unwanted/not useful files or data on your N73. if it has a memory card, try get a new 1 for another memory storage...
May 24, 2010 | Nokia N73 Music Edition Smartphone
Hi.. My nokia N73 is always showing as phone memory full delete some data.. i have done resetting the phone multiple time still it is showing same problem ..
try ( * + '3' + 'call button') hold this three keys and power up ur mobile without simcard dont leave the button untill u get the countries name for further details.be sure to save or backup data saved in your phone and memory card. this format will remove each and every file saved in your phone memory or memory card which cannot be restored if deleted once..
May 20, 2010 | Nokia N73 Cellular Phone
N73 Cellular Phone: my nokia n73 memory low delete some data sir what ...
This problem Arises When your Phone memory(C:\ Drive) Is almost Full .normally C: Drive Has 44.4MB Space. But When it goes below 500KB,it shows
"memory low delete some data"
So delete unwanted files from phone memory using any Good File managers .One i suggest is Using "Xplore" An application for n73
Which can be downloaded Here
Or else use Phones inbuilt file manager to delete unwanted files from phone memory.
Hope this will solve your problem
(Alternate download Path Click HERE)
May 16, 2010 | Nokia N73 Cellular Phone
N73 when i try to open bluetooth application it show error msg as unable to perform bluetooth operations wht to do ??????? please suggest once i had already restored by*7780# still same problem continues
The error massege shows as unable to perform bluetooth operations when memory is full.
Try to delete some of the data applications and try to perform the bluetooth operation.
Even if you find the same problem to perform bluetooth the remove the battery when the mobile is switched on and remove the sim and reinsert after 2 mins.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 09, 2009 | Nokia N73 Cellular Phone
Mamory full,delet some data,
question is not completed , if it is full in phone memory delete some data
Apr 15, 2009 | Nokia N73 Cellular Phone
How to delete some data in my nokia n73?
Try to delete songs or setups that you might have kept in the phone memory (c:) drive of your phone !
and make sure no application is running in background before opening LifeBlog.
For better viewing of the files kept in the phone memory use X-PLORER software !
It rockx.
Thanks
Apr 09, 2009 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
