Viewsonic model vs10846-1m aka N4060W won't turn on.
Wouldn't turn on intermitantly at first. Now won't turn on at all. Viewsonic suggest it is the power supply. Any ideas?
  • 2 more comments
  • Anonymous Mar 31, 2009
    same problem here, i was also told by TV repairman it sounded like the power supply.
  • yapper70 May 12, 2009
    Was it the power supply? Do you have that part number?
  • yapper70 May 13, 2009
    Did the power supply replacement fix the problem? You wouldn't happend to know the part number do you?
  • Jose Antolinez
    Jose Antolinez Nov 12, 2013
    Alguien me podria decir donde encontrar la fuente de alimentacion del viewsonic VS10846-1M N4060w LCDtv debido a q la bote y no se como encontrarla, donde podria comprarla?
I found if you hold the power button down on the remote or the tv , hold it down for anywhere from 2-5 minutes the green light will blink and blink and blink, all of the sudden it will stay on. then shut off, but if you turn it back on on the light will again stay on , do this 3-4 times and then the tv will turn on. Once you turn it off for over 10 minutes you will have to go through the whole rigamaroo again. This will only work for a while, mine has quit completely now. The Veiwsonic guy gave me a part number for a power board he said was most liley the issue. It ran about $71. I've got a repairman coming tomorrow to see what the dealio is. I'll let you know what he tells me, good luck!
Posted on Mar 31, 2009
  • Eliborio Camacho
    Eliborio Camacho Nov 15, 2013
    Did anyone ever get a working solution to this problem? My unit has the exact same issue. Was anything attempted and what were the results. I know this is an old issue but i thought i would give it a shot before trying on my display. Thanks
N4060w comes on but no blue screen or menu.
OPPS! Have you tried putting the old board back to see what you have?
Jun 15, 2012 | ViewSonic NextVision N4060w 40 in. LCD...
Viewsonic N4060w tv
Ur tv the LCD inverter board is dead.Replaced the LCD inverter board u will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy an refurbish LCD inverter board for the replacement.It a long board in shape.
May 31, 2010 | ViewSonic N4060w 40 in. LCD TV
Power problem for viewsonic n4060w lcdtv. red light comes on for half a second then goes off but no picture appears. also, may work if you turn it on or off 20 times....it just wont "catch".
I had the exact same problem with my set 6 months ago. Had the repairman look at it and it ended up being a faulty/weak power source. He told me that he could either work on the power source himself or just buy a new one. New ones are very expensive and hard to come by, but he was able to fix the existing one. Got the whole thing fixed for something around $350 to $400. Pretty steep and made me consider buying a new one, but I didn't. And now its on the blink again, so you might consider that.
May 21, 2010 | ViewSonic NextVision N4060w 40 in. LCD...
My Viewsonic N4060W 40" LCD TV will not come on, i get a steady green light when power button is pushed but the screen is blank and no sound. My TV is 3 years old and just last year i had a somewhat...
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. If the tech installed a used power supply, it may be bad also. 3 years are typical for capacitors to go bad.
Nov 15, 2009 | ViewSonic NextVision N4060w 40 in. LCD...
Viewsonic n4060w power but no menu or source selection....
hello, you will need to locate a service manual for it.
cd or downloaded it costs a few dollars but it is worth it.
if your going to open it might as well know what to check for.
you need it to service your set.
not processing signal, menu not displaying,
sound like internal board issues.
good luck hope this helps
good luck
hope this helps
Dec 21, 2008 | ViewSonic NextVision N4060w 40 in. LCD...
LCD TV N4060w can not power on
I had the same problem...first it would take two or more power button presses to get the tv to turn on. Finally it would not turn on. It was the power supply and was easy to replace.
Dec 16, 2008 | ViewSonic NextVision N4060w 40 in. LCD...
Cracked lcd on viewsonic n4060w
Ultimately repairing the screen is up to you, LCD's are not cheap.
If you decide not to repair it, I'd be interested in the boards off yours.
OR
You can by mine, (LCD) is in good shape.
Dec 01, 2008 | ViewSonic NextVision N4060w 40 in. LCD...
ViewSonic NextVision N4060w 40 in. LCD TV, will not turn on.
While this isnt an exact fix at work, you will at least be able to view your tv. We have one at work that would do nothing when you hit the power on button, just the usual geen led flashing. We pulled the cover off and found the bulging caps, more than likely from brown outs. But we also found that none were holding a charge. So we held the power button on for at least five min, after the led would stay on for about 30 sec and then turn off. We kept hitting the power button and the screen would try to come on. It finally did. After it did come one we can power on and power off aslong as we dont turn it off for more than 10 min. After 10 min of it being off we have hold down power button again and start the whole process again. So the main problem i believe is the caps arent holding a charge, to be able to kick the high voltage circuit on. We did not replace any caps but if we do end up changing parts will post what was changed and cost. Hope this helps
Nov 04, 2008 | ViewSonic NextVision N4060w 40 in. LCD...
Viewsonic n4060w does not turn on
Welcome to our world... http://www.fixya.com/support/t285490-viewsonic_n4060w
This thing needs to go to a state attorney general if Viewsonic isn't even will to provide parts for these pathetic LCD TVs.
May 21, 2008 | ViewSonic NextVision N4060w 40 in. LCD...
Viewsonic n4060w
HI I AM A TECH. I WORK FOR A COMPANY THAT REPAIRS LCD TV'S. IF YOU HAVE SOUND AND NO PIC YOU WILL NEED AN INVERTER BOARD THERE IS A WEB SITE CALLED SHOPJIMMY.COM THEY MAY HAVE IT
Dec 06, 2007 | ViewSonic NextVision N4060w 40 in. LCD...
Televison & Video Logo
1,161 people viewed this question
Top Televison & Video Experts
