Question about Acer Aspire 5610-4648 Notebook
What reason to courrept .ear file in jsp server?
I have file courrept error on my project.
so please inform reason and solving method to rectify this problem.
  • DEKR
    DEKR May 11, 2010
    please tell me what error message
Outlook: None of the authentication methods supported by this client are supported by your server
For more information about repairing or configuring your Outlook email account, click the following link:
https://www.pstrepairkit.com/
Regards,
Arnold Warner
Oct 17, 2016 | Computers & Internet
How do I recover data from .mdf file
Detach you database. Overwrite the mdf and ldf files you've restored from your backup with your files from the D: drive. Reattach the database.
There is no guarantee that this will work or if it works, that your database is in a state where you can continue to work with.
If that doesn't work then there is an option to try to restore database using SQL Server Recovery Toolbox. It is a powerful tool for data recovery. They have a demo version. So you can check it works in your situation or not.
http://www.oemailrecovery.com/sql_repair.html
Jan 19, 2016 | Microsoft SQL Server 2008 Enterprise Full...
Recover data from corrupt .mdf and .ldf files.
You can find more information here:
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/569-i-have-a-problem-how-do-i-fix-a-corrupted-database-file
Open your SQL Server Management Studio console. This application shortcut is available in the SQL Server directory in the Windows Start button.
· Enter the system administrator user name and password. SQL Server's administrator user name is "sa." This account is required for privileges to restore the database. If your restoring on a host provider server, use the administrator user name and password they supplied for your account.
·Right-click your database name and select "Attach." In the new window that opens, click the "Add" button to open a dialog box.
·Select your MDF file and press the "Ok" button. It may take several minutes to restore the database if it is a large file. Once the process is finished, browse your tables to verify the data. The database is now restored.
If nothing helped try to use:SQL Server Fix Toolbox
http://www.fixsqldatabase.com/
Nov 28, 2014 | Microsoft SQL Server 2000 Standard Edition...
Netflix error 405
http://forums.mozillazine.org/viewtopic.php?f=38&t=605984&p=3155060
http://www.checkupdown.com/status/E405.html
SYMPTOMS
When you browse the default document, you receive one of the following error messages: HTTP Error
405 Method Not Allowed
The method specified in the Request Line is not allowed for the resource identified by the request. Please ensure that you have the proper MIME type set up for the resource you are requesting.
Please contact the server's administrator if this problem persists.
HTTP 405 - Resource not allowed
Internet Information Services
This problem occurs if the following conditions are true:
  • You do not specify the file name. For example, you do not specify http://Server/Web/.
  • The Scripting Object Model (SOM) is enabled.
  • A DTC event is called.
CAUSE
This problem occurs only when you use Microsoft Internet Information Services (IIS) 4.0 and Microsoft Internet Information Services 5.0. This problem occurs if you send a POST request to a server that is running IIS 4.0 or IIS 5.0, and the POST request contains a URL that ends in a slash mark (/). IIS returns the 405 error message instead of the default document. However, if the method value of the Verb property is GET or HEAD, IIS returns the default document. RESOLUTION
When the SOM is enabled and a DTC event is called
When the SOM is enabled for the page, a <FORM> tag that is similar to the following is inserted in the page. <FORM name=thisForm METHOD=post>
Because no ACTION attribute is specified in the tag, both Netscape Navigator and Internet Explorer try to make an HTTP POST request to the URI "web/". According to the HTTP RFC (RFC 2068), this is not a valid Request-URI for a POST operation.
To work around this problem, use one of the following methods:
  • Redirect from the default document to a different document. In this case, the SOM-enabled document will no longer be the default document. The new default document will just redirect to the SOM-enabled document. For example, if your SOM-enabled document is named MyDefault.asp, the default document (Default.asp) will contain only the following code. <% Response.Redirect "mydefault.asp" %>
  • Use client-side script to make sure that the file name is included in the URL. If you must use your SOM-enabled document as the default document, use a client-side code block that is similar to the following code block as the first code block within the <HEAD> section of the page. This code block does the following location replacement. Language=JavaScript> var loc = document.location.toString() var loclen = loc.length //The name of the default document var filename = "default.asp" var filelen = filename.length loc = loc.substring(loclen - filelen, loclen) if (loc.toUpperCase() != filename.toUpperCase()) { location.replace(filename) }
When the remote scripting is called
This problem may occur if you use the window.location.href property in an HTML document to determine the path of the current document. If you do this when you initiate a remote scripting call, the remote scripting call fails because the client page does not have a file name.
To determine whether the page can use remote scripting on the client, verify that the value of the window.location.href property does not end in a slash mark. To provide a file name in the client browser, and to prevent the error on the server, use the Response.Redirect method redirect the request from the default page to another page. For more information, see the first resolution method in the "When the SOM is enabled and a DTC event is called" section. STATUS
Microsoft has confirmed that this is a bug in the Microsoft products that are listed in the "Applies to" section.
This bug was corrected in Microsoft Internet Information Services 6.0. Properties Article ID: 216493 - Last Review: 11/21/2006 13:13:42 - Revision: 3.2
Applies to
  • Microsoft Internet Information Services 5.0
  • Microsoft Internet Information Server 4.0
Keywords:
  • kbbug kbctrl KB216493
Apr 20, 2014 | Netflix Computers & Internet
Please describe solution of error 413 problem:
HTTP Error 413 Request entity too large
Introduction
The Web server (running the Web site) thinks that the HTTP data stream sent by the client (e.g. your Web browser or our CheckUpDown robot) was simply too large i.e. too many bytes. What constitutes 'too many bytes' depends partly upon the operation being attempted. For example a request to upload a very large file (via the HTTP PUT method) may encounter a ceiling on upload file size set by the Web server.
413 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle:
  • Obtain an IP address from the IP name of the site (the site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from the Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receive an HTTP status code that it recognises as '413'. Frank Vipond. September 2010.
Fixing 413 errors - general
This error seldom occurs in most Web traffic, particularly when the client system is a Web browser. The problem can only be resolved by examining what your client system is trying to do then discussing with your ISP why the Web server rejects the number of bytes sent by the client system.
Fixing 413 errors - CheckUpDown
This error should simply never occur on your CheckUpDown account. If it does, it typically indicates defective programming of our systems or of the Web server which manages the site. The length of the HTTP data stream we normally send is relatively small and well within the limits of what most Web servers should accept.
Please contact us (email preferred) whenever you encounter 413 errors - there is nothing you can do to sort them out. We then have to liaise with your ISP and the vendor of the Web server software to agree the exact reason for the error.
hope this helps
Mar 01, 2011 | Computers & Internet
What is run time error '-2147467259(80004005)' how i solved it rewati nadan
"The Microsoft Jet Database Engine cannot open the file '(unknown)'"There are several causes for this error message:
  • The account that Microsoft Internet Information Server (IIS) is using (which is usually IUSR) does not have the correct Windows NT permissions for a file-based database or for the folder that contains the file.
  • The file and the data source name are marked as Exclusive.
  • Another process or user has the Access database open.
  • The error may be caused by a delegation issue. Check the authentication method (Basic versus NTLM), if any. If the connection string uses the Universal Naming Convention (UNC), try to use Basic authentication or an absolute path such as C:\Mydata\Data.mdb. This problem can occur even if the UNC points to a resource that is local to the IIS computer.
  • This error may also occur when you access a local Microsoft Access database that is linked to a table where the table is in an Access database on a network server.
Resolution
  • Check the permissions on the file and the folder. Make sure that you have the ability to create and/or destroy any temporary files. Temporary files are usually created in the same folder as the database, but the file may also be created in other folders such as the WINNT folder. For additional information about how to identify which folder does not have the correct permissions and how to configure temporary files, click the following article number to view the article in the Microsoft Knowledge Base: 253604 (http://support.microsoft.com/kb/253604/ ) Microsoft Access 97 database connectivity fails in Active Server Pages If you use a network path to the database (UNC or mapped drive), check the permissions on the share, the file, and the folder.
  • Verify that the file and the data source name (DSN) are not marked as Exclusive.
  • The "other user" may be Microsoft Visual InterDev. Close any Visual InterDev projects that contain a data connection to the database.
  • Simplify. Use a System DSN that uses a local drive letter. If necessary, move the database to the local drive to test.
  • Follow the instructions in the following article to work around this problem: 189408 (http://support.microsoft.com/kb/189408/ ) FIX: ASP fails to access network files under IIS 4.0 and IIS 5.0
Oct 16, 2009 | Microsoft Access 2003 for PC
Opening file problem
There may be compatibility problems. Do a repair using add/remove programs. There may be problems with COM components also. Right click on my computer icon and go to manage. From there go to Event viewer snap-in. There are logs for office softwares. Examine that. If there is an error it will be listed there.
If this is helpful to you, please rate. Thank You!!!
Jun 15, 2009 | Microsoft Office Excel 2003 for PC
.ear or .war files
There's no easy answer to these as there are too many variables to consider. The first issue is to correct you on one point - HTML and JSP files cannot be made into an "executable file" (like a Windows .exe file) but must be placed onto a web server that can process JSP files.
The most common JSP web server is called Tomcat and can be downloaded for free from http://tomcat.apache.org. This application will allow you to run your project on your local computer or network but it is unlikely (difficult or not possible depending on your ISP) you will be able to make this accessible to other Internet users. This is usually only good for testing to see if your application works properly (which you should do before putting it on the Internet)
If want other people to access your web project you will need to find a commercial hosting provider that allows you to host JSP-based websites. These are actually not so common so you will have to look around the Web to find a good one at a good price.
As far as using Tomcat web server is concerned I would refer you to the manual at the website you downloaded it from. With JSP projects it is not always as easy as copying your files to the server and having it work straight away - sometimes you need other library files and sometimes you need to configure the server correctly with details about your web application - all depending on how you created your JSP project (which I don't know enough about).
If you haven't already, I recommend using the free Netbeans application from http://www.netbeans.org to develop your JSP projects as it makes it much easier, comes with a built in JSP web server and there are a lot of good tutorials and instructions at their website to make it easy to get your web application up and running.
Once you get over the initial problem of how to run JSP web applications, using JSP is a lot of fun and very powerful.
Let me know how you get on or if you need any more help.
Apr 18, 2009 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
