Question about Nintendo Wii Console
My controls wont work
I get a blue light on the unit, but my controls wont do anything, they dont light up,makesound,uoshow a curser or cross hairs on the tv. i tried new batteries, and syncing theremotes but the just dont seem to work. ant help please.
  • bernie847 Feb 05, 2009
    One of my controllers has a blue light on it but when we select two players on the mario cart game it comes up with a message saying something about no connection etc. etc. I have tried new batteries but the problem was not solved.
  • jetremi Feb 05, 2009
    I am also having issues with my Wii
    the controls dont register and also the Wii fit board
    I have changed batteries and tested the batteries
    sinync the controls and board
    still will not work
    any ideas are very welcomed
  • 257 Answers
Hi, Sounds like you need to check the sensor bar. Make sure it is plugged in or if you have a remote sensor bar check it's batteries. If this doesn't work you can clear the console sync info by turning off the console power, unplug the console for a few seconds, plug it back in and turn the power back on. When you get the Health and Safety screen, press and hold the console synchro button for 15 seconds. Now resync your wimotes by using the red buttons in the remote battery area rather than the screen sync. If you need more help let me know as there are other things like a stuck button on a controller to look for. Good luck!
Posted on Jan 28, 2009
  • Jim London
    Jim London Feb 04, 2009
    Hi, I hope I solved your problem, Please rate my response, your
    favorable ratings help others that may have the same or similar
    problem. Thank you!
Signal lights wont work but emergency lights do?
Check if there is voltage feed to the signal switch in the cluster. If not the fuse must be checked. Also the feed to the signal control circuit needs to be checked or it can be fault in the wiring or connection to the unit.Cross check the signal unit with an external input.
Dec 29, 2011 | 1999 Ford Explorer
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
Does it take some type of gel under the lights, the colors are a little blurry
i also have this tv. i removed backcleaned mirrior, back of screen and lenses VERY GOOD. Then turned on tv go to convergence, sepaerate cross hairs then adjust focus on lenses. Then lenses rotate maybe about a 1/3 turn total by hand. Grab ring that houses lenses and turn until cross hairs are as clear as possible. This can be done with out help by watching inside of screen. red and green are adjustable, the blue is adjustablealso but i couldnt find blue cross hairs, maybe by covering red and green lenses the blue will show on screen. anyway when done and cross hairs are clear,lenses, mirror and screen are clean, you can adjust covergence and get a very clear screencleaning will also brighten pic. Pete
Mar 27, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have a ultrascan hd the convergance is off i dont have an owners manuel it tells me to use a curser what do i do to get the red blue right ?
The cursor probably is just a cross in the center of your TV screen whichever color your setting will be a color cross that you want to move by using the up, down, left, right, buttons on your remote. You want to move your color cross over the top of the center cross until it looks like one cross. Generalized setting instructions can be found here.
If this helps let me know with a vote.
Mar 04, 2010 | Televison & Video
I have a 3-12 by 40 rifle scope made by tasco i dont have thewaranty paper work any more and the cross hairs wont adjust any more what do i do
i dont realy understand what you mean by "the cross hairs wont adjust" is it you have ran out of adjustment on the turrets? if so try packing the scope out with 35mm film under the body of the scope and reclamping it,,,or do you mean it just wont adjust?
the tesco rifle scope is a realy cheep scope its a throw away kind of thing if it brakes,,,,there only £50 or so,,,,if it was a £1500 scope its worth fixing
Nov 16, 2009 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
Convergence line will not move to match cross hairs
the green line will not move. it is stationery and red and blue have to adjusted to it
Jul 20, 2009 | Panasonic PT-51HX42 51" Rear Projection...
My wii controllers wont work
you dont have lights on any one of your controllers?
have you tried them with another console or another controller with your console? this way you can find out where the problem lies with either the controllers or the console. to me it sounds like the console is the problem. How long have you had the wii and did the conttrollers ever work?
Jan 28, 2009 | Nintendo Wii Console
Why wont my wii controlers work?
I just had the same problem and the solution is pretty simple.
Step 1: Make sure system is off
Step 2: Unplug system from outlet and leave unplugged for a couple minutes
Step 3: Plug back into outlet and turn on the system
Step 4: Sync them up
Also, a frozen system that is not responding both through the controller and can be fixed simply by unplugging it from the outlet and giving it a couple seconds.
Wont let you go to convergence blue? can you pull up the customer convergence menu
DO you get the blue cross hairs?
Nov 29, 2007 | RCA HD52W59 HDTV Projection Television
you have bad convergence ics
Apr 13, 2007 | Toshiba TP61H60 61" Rear Projection...
Nintendo Wii Console Logo
142 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
