Question about Canon PIXMA iP1600 Printer
Error code 5100 on canon pixma 6600d
After replacing cartridge BK, an error code came up and printer seems jammed in some way. Have turned off and on again but problem remains.
  • 4,041 Answers
Hi You can Try
Error Code 5100 ok try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
My Canon Pixma MP130 keeps giving me the 5100 error. Can't even complete the nozzle print test. The ink cartridges do not appear to be jammed as they move. What is the problem? Please help.
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
May 22, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I am getting an error 5100 message. On the printer it says cartridge jammed thanks
Hello and WelcomeError 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
If it is HELPFUL, Please Rate it as Four Thumbs THANKS
Mar 08, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Printer is giving me an error 5100 error code. What does this mean?
Error 5100 points to a "carriage jam" .The carriage is the assembly that contains the printhead and cartridges.
I hope this helps
Mar 08, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Says E on LCD with a flashing 2 and alarm light Canon Pixma MP150 Error Code 5100
Either you replaced your printer cartridge or your ink is over or there seems to be a paper jam.
I have a Conon MP160,I got the same error when I got my Cartridge re-filled by a local re-filler,but the printer works fine.
Go to Printer Maintainance(Click the Printer Settings Wizard on Control Panel),all your problems get resolved there
Thank You.
Feb 13, 2011 | Canon Office Equipment & Supplies
I have an error - "cartridge jammed" pop up window advises to re
Please refer to Canon web site for specifics on resolving cartridge replacement and error 5100.
There's even pictures to help.
Apr 11, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon error 5100 cartrige jumped
I think you are seeing "ERROR 5100: Cartridge Jammed", right?. Here is the most likely solution to this issue with your printer. The following procedure comes directly form Canon
ERROR LCD: CARTRIDGE JAMMED
1. Press ON/OFF switch to reset the multifunction device 2. Removing obstructions, foreign objects and paper jams MP750 / MP780 3. Reseat MP750 / MP780 print head 4. The MP780 may require repair
Feb 08, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP130 error 5100
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Mar 16, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
91 people viewed this question
old marine
old marine
