Question about Jeep AM/FM Cassette with CD Changer Controls - Upgrade Swap
Volume knob does not work
On my 2001 Jeep Wrangler, the volume knob stop working. Sometimes it works and others it doesn't. I might try lowering it and the system will turn louder. It's just gone crazy. Now it just stoped working completely...
Any ideas on how to fix this?
    Scholar:
  • 116 Answers
Get some tuner cleaner (radio shack etc.) and using the thin straw it comes with, spray generously into the volume knob shafy (removethe plastic knob first). Spray while rapidly moving shaft back and forth. Repeat 2-3 more times and all should be good. You have dust builup inside, causing it to go haywire!
Make sure you do this with the stereo OFF!
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
My headlights, blinkers, and reverse lights still
trace all the wire sounds like its shorting out on something else
hope this helps
Aug 29, 2014 | 1998 Jeep Wrangler
I don't know how to change the minutes on my clock. It's a jeep wrangler. I've tried holding in the time button and turning tune knob, doesn't work. Thanks!
is there a h/ m with two little holes any where on the radio? usually on the right or left of the clock. if so stick a paper clip into the hole and set. if not i would try the FF and the RW buttons
Mar 11, 2013 | Cars & Trucks
06 wrangler blower fan stops working
I'm not following your story.
Does the blower motor stop working from time to time ?
Have you checked the motor for power and ground when it is not working ?
Feb 11, 2013 | 2006 Jeep Wrangler
2001 Jeep Wrangler heater blower stopped working
Yes I would go with the switch, BUT, does it have a resistor bank? That is, how does it reduce the speed? Many systems use resistors to lower the speed. Burnt or bad connections can cause this as well.
You can test the blower motor by connecting direct power from a source like the cigarette lighter if you are handy.
Most of the time the lower speeds konk out but the high speed continues to work this is the resistor bank that goes out.
Mar 25, 2010 | 2001 Jeep Wrangler
Winshield Wipers stopped working on a 2001 Jeep Wrangler.
TAKE IT BACK THEY HAVE LEFT A LINK OR POWER FEED LOOSE
Dec 07, 2009 | Jeep Wrangler Cars & Trucks
The air conditioner wont stay on.
Do you mean the blower motor? Check resistors.
Jun 29, 2009 | 2001 Jeep Wrangler
Trying to put a new gear shift knob on but cant the old one off
it's a screw on type...at first it's hard to turn but after turning counter clockwise real hard you'll be able to loosen the shifter iknob
May 30, 2009 | 2001 Jeep Wrangler
3rd brake light won't work. Replace bulb...nothing
The contacts for the third brake light are two silver discs, about the size of a dime. They are located on the inside of the tailgate, hinge side. Make sure your carpet or any other loose item has not covered one or both contacts. Make sure they are fairly clean and make good contact.
Nov 29, 2008 | 2001 Jeep Wrangler
Anyone ever have a problem with tach and speedometer
hello try to tap on the dash area were the tach and speedometer is also dash area possible loose cluster contacts jiggle goodluck
Sep 18, 2008 | 2000 Jeep Wrangler
Car Audio & Video Logo
927 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
