Question about Plantronics CS520 Wireless Headset
How do you pair a CS520 to its base - Plantronics CS520 Wireless Headset
How can I get my wireless headset CS520 model to answer a call without having to lift the phone receiver first?
A headset button can be added to the phone that when pushed will activate the headset port on the phone. Once added the light will light when headset mode is active. This button can be added through the multi-line set key assignment for in the mitel. I would also suggest added a release button at the same time as the release key would be used to disconnect a call in headset mode.
Mar 09, 2015 | Mitel 5330e IP Phone 50006476
At&t model dect6 troubleshooting
You probably just need to Pair the handset with the base again.
So, you have to set the phone in the main base, not just a charging base.
Some of the AT&T phones need you to disconnect the battery for about a minute to reset (this will not lose you stored numbers). Then pair the phone and base again.
Some models have a PAIR button on the bottom of the base.
Press and hold the PAIR button until the MUTE light on the headset base turns on (about four seconds) and release the button.
Return the headset to the headset base for registration.
Registration may take about 30 seconds to complete. The MUTE light on the headset base turns off. The headset ON/OFF light turns blue
on the first headset registered. The headset ON/OFF light turns orange on the second headset registered.
You should be good to go!
All the best to you,
Kerry Hostetter
May 11, 2014 | Computers & Internet
Need to pair with base
What do you need to pair, with what base?
Feb 26, 2013 | Computers & Internet
Phone lifter not working. light on top of base not lit up
Try re-pairing the headset to the Plantronics 500A base unit, it sounds like the headset may have lost connection with the base. Here is the link for the pairing instructions:
Plantronics 500A Pairing Instructions
Good luck from Headsets Direct!
Jul 06, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
Mar 13, 2011 | AT&T CL82409 Cordless Phone
Headset not working. red light on base is flashing and yellow light is static; no blue light
It sounds like the headset may have lost connection with the base, try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Feb 09, 2011 | Plantronics Voyager 500A Deskphone Adapter...
We had to order a new headset (ear piece) to our CS70 system. Do we need to program it? It is not picking up the handset.
To pair another headset to the same base, you must first enable the multi-shift
pairing feature. Long press (5 sec.) the speaking volume minor adjust up button on
back of base until the power indicator light flashes.
2. Place a charged headset in charging cradle and red indicator light on base will flash
for 2 seconds if the multi-shift pairing feature is enabled. Within 10 seconds of
doing so, press either the "+" or "-" listening volume button for 3 seconds until the
headset talk indicator lights to indicate pairing mode, and goes out after successful
pairing. Repeat steps
Jul 11, 2010 | Plantronics CS70 Wireless Headset
Base set fine - additional handsets dont work
The additional handset and the base need to "pair" first. Put the handset in the base cradle till you see the red light blinking. That's when they are paired.
Nov 07, 2007 | GE 25951EE2 Phone
Plantronics CS520 Wireless Headset Logo
Top Plantronics Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Plantronics Lands Phone Expert? Answer questions, earn points and help others
