Question about Toshiba 40UX600U TV
Toshiba 75014701 Assy, Base - Toshiba 40UX600U TV
How do you assemble the base stand assy?
You can find instructions for the base assembly for that model here on YouTube:
VIZIO Series Base Installation
Apr 16, 2016 | Vizio E260MV 26" 1080P LED Television...
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Error code e 550 in estudio232
This is caused by a bad sensor located at the bottom of the by pass assy. To get to it the duplexer assy and the by pass assy have to be removed.
Mar 07, 2013 | Toshiba e-Studio 232 Black and White...
Need a bulb for a Toshiba RPTV, model TW56x81, but can't find the part number?? Thanks
Toshiba 23003818 Picture Tube Assy, Coupling, B [V903b] Toshiba 23003781 Picture Tube Assy, Coupling, G [V902g] Toshiba 23003817 Picture Tube Assy, Coupling, R [V901r] Here's the part numbers for each of the CRT's. This set doesn't have a single bulb like you mentioned. Your problem is most likely elsewhere in the power supply or Horizontal output circuit. Good luck
Bill W
integrityhomeworx.com
Mar 22, 2011 | Toshiba TW56X81 56" Rear Projection...
Replaceing rear signal light
1. Remove the two small Phillips head screws holding the inside edge of the Taillight assy (you have to open the tailgate)
2. Pull straight back on the Taillight assy levering most of your pressure to the outside edge.
(There is two peg like things [top and bottom of the assy]stuck into a tight fitting hole in the body, so it will take some effort, as they are pretty snug..but, they should eventually pop out)
(Put a dab of vasoline on the pegs before you stick them back in, this makes future entries easier)
3. Twist each lamp base 1/4 turn CCW and the lamp base/holder will come right out of the Taillight assy.
4. While grasping the bulb, Pull straight out from the base..Insert new Bulb.
(Spray a little lubricating contact cleaner in the socket and on the bulb base, before you put the new bulb in.)
5. Add a little vinly/rubber spray protectant to the rubber gasket on the base.
6. Re-install Lamp and base into Taillight assy using a 1/4 turn CW twist of your wrist
7. Align the pegs on the Back of the Taillight assembly with the mating holes on the body.
8. Gently, but firmly smack the Taillight assy with the heel of your hand,to seat the pegs.
9. Re-install and tighten the two screws and go wipe off the finger prints and smudges from Taillight assy lens.
Mar 05, 2011 | 2006 Hummer H3
I need a pedestal stand for my Toshiba 42RV530U. Do you know where I can get one?
Manufacturer Toshiba Part Number 75010935 Description BASE BASE ASSY, BASE
Aug 08, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Need screw specs to attach base assy to tv
I
Hi there, if you are trying to just remove the base, then on your model there is one screw in the center of the underside of the base. If you want to remove the neck of the base to then remove the 8 screws on the back of the tvs neck too. I hoped this helped, please rate thank you!
Feb 05, 2010 | Vizio Televison & Video
Toshiba 40UX600U TV Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
