Question about JVC HX-Z10 CD Shelf System
Turn on Daily On Alarm Clock
I don't know how to turn on Daily Alarm Clock on My JVC HX- Z10.
  • 944 Answers
The instruction manuals are on this link; http://books.jvcservice.com/booklist.asp?Model=HX-Z10 Hope this helps :)
Posted on Jul 24, 2007
SOURCE:
Subwoofers arent working
Try looking in the FIXYA section for electronics.
Mar 06, 2014 | JVC HX-Z10 CD Shelf System
Jvc hx-d7 sound If I turn the volume knob down to fast the volume turns up. Any ideas?
The contacts in the volume control encoder are dirty. If you know what you're doing, it can be taking apart and cleaned, otherwise replace the volume control.
Jul 08, 2013 | Audio Players & Recorders
C9 champion digital alarm
Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
May 10, 2013 | Watches
Please,tell me how do I turn off my self timer on my JVC micro component UX-lp5
Press CLOCK/TIMER repeatedly to select "DAILY 1", "DAILY 2", or "DAILY 3", then press CANCEL. See page 2 of this manual.
Mar 27, 2013 | Audio Players & Recorders
Problem with launcher Pro and alarm clock. No way to turn it off or to put on snooze. I can't switch off my alarm clock or snooze. I have to turn off the phone completely to make it stop. I use...
I had the same problem the other morning. All I wanted to dowas go back to sleep, but the alarm would not shut off.
Here is how to fix it:
Go into the clock, then alarm clock and click the menu button, then settings. Go to Slide Button Behavior, which will give you threeoptions, choose none.
Now, when your alarm goes off there will be a pop up and you can either choosedismiss or snooze. Please don't forget to give thumbs up!!
Jul 13, 2011 | McNeil-PPC Android Apps
I can't turn the alarm off so that it won't go off daily. Right now it goes off everyday and I don't want it to.
If you click the "alarm" button repeatedly you can pick what you want to wake up to. Do this until the only little picture lit up is the alarm clock picture. That will turn of the alarm.
Jan 09, 2011 | GPX CI109 Clock Radio with Dock for iPod ...
My JVC CA-HX-Z10 works just fine but the speakers tend to turn off. I unplug it for a couple of hrs and then plug it back in and it works just fine for a couple of minutes and then the sound just goes off....
This is a semiconductor or capacitor thermal problem. You will have to be able to get to the circuit boards. With a can of Electronic Cold Spray (freon), you turn the unit on until it heats up and the sound goes out. Then, try spraying transistors and components once at a time, until the sounds comes back on. This will be the bad part. You will have to unsolder it and take it to Radio Shack or electronic parts store, or possibly order one online (google the part number, or value on the capacitor, etc.). Problems like these are usually transistors, and they usually only cost a few dollars (maybe $25 at the most). Inspect solder joints to see if they're cracked, or discolored (indicating a "cold-solder" joint, which you can resolder with fresh solder applied. The hardest part of fixing this type of problem, is that you have to sometimes take it all apart to get at the back of the circuit board to unsolder the bad part. Take pictures as you take it apart- they will help you putting it back together. Good luck!
Apr 22, 2010 | JVC HX-Z10 CD Shelf System
GE Model 7-4837B
press the Cancel button located on the top of the alarm clock (the light next to the wake mode indicator on the front of the clock should start flashing). Then press the WAKE Mode button on the top of the device. The wake mode indicator on the front should now be off and the alarm deactivated.
To turn the alarm back on, simply press the WAKE Mode button on the top of the device.
Mar 27, 2008 | GE 74801 Clock Radio
Cd shelf
The hx-z10 mini stereo system is giving me the same problems again.
Aug 31, 2007 | JVC HX-Z10 CD Shelf System
JVC HX-Z10 CD Shelf System Logo
172 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
