Question about Toshiba Office Equipment & Supplies
What does status 0050 mean on a toshiba e-studio 255se
Fax receipt code shows a status code of 0050, What does that mean ?
It means there is no dial tone on the fax line, is the rj11 plugged in properly [ (Line) on the copier, not he one labeled as (TEL) ], is the telephone patch defective, or you have an active phone on the wall jack, (test it it with an ordinary phone), or the receiving party is busy, try later, or try a different nunber.
May 05, 2014 | Toshiba E-Studio 206L Copy Machine
FAX NOT SENDING
make sure your connected in the right plug one is for a hand set also see if your getting a dial tone could be bad line if that checks ok then replace lcu pcb
Jan 09, 2013 | Toshiba E Studio 2330C
How to take the meter reading of the number of copies on toshiba copyworld Studio 35
you have to press the job status bottom and then press status, and show it
Sep 10, 2010 | Toshiba e-Studio 35 Copier
How do you reset Admin on a Toshiba e-studio 162D
In the manual it says to "Turn on power while holding down the status button on the network expansion kit. Continue to hold down the status button until a beep sounds."
It looks like the default password was TOSHIBA which took me forever to find. The user name should just be admin.
Feb 25, 2010 | Toshiba e-Studio162D Copier
Toshiba studio 4511 problem
This could quite literally mean anything from a new drum to fuser unit to power supply etc.
Sep 21, 2009 | Toshiba e-Studio 282 Printer
Status NG BO
POWER OFF THE MACHINE PRESS 1 3 *(star) together. switch on machine while holding this three sw.
machine will rest.
May 05, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
My toshiba e-studio 550: service recommended for SPC appeared
Check the control status of the surface potential sensor (05-242).
<When “4” is displayed: sensor error>
The sensor detection value is abnormal or the sensor output value is not changed even though
the main charger bias value is changed.
Is the connector of the surface potential sensor connected properly?
Is the main charger grid/wire attached poorly?
Is the main charger attached poorly?
Are leaks and such occurring?
Mar 05, 2009 | Toshiba E-STUDIO 550 Copier
C448 on Toshiba e-studio 2500c
C448 indicates Heater lamp lights continuously for a certain period of time when the pressure roller temperature during ready status is higher than the specified.
1. Clear status counter
Enter 08--> 400 --> change the value from "32" to "0", press Enter and restart MFP.
If occur again, u need to check followings:
1. Check the power supply and fuser unit
2. Check the LGC board
Feb 04, 2009 | Toshiba E-Studio 161 Copier
208 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
