Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
Electrolux dishlex dx 302/403
Dishwasher not completing cycle stops all the time beeping code 10
SOURCE: Dishwasher Dishlex DX302WB No Hot Water
BRILLIANT !!! Thanks for the fix.
I've attached these two photo's below to help folks with wiring & showing the obvious fault
Posted on Aug 11, 2008
  • 294 Answers
SOURCE: dishlex 302 SJ dishwasher on quick cycle beeps and shows 20 ...?
Posted on Apr 11, 2009
  • 12 Answers
SOURCE: Not drying dishes
The fact that it does not work on all three settings suggests it's something common to all three. Sounds like perhaps your immersion heater is bad or even worse, some contacts or relay in the control circuitry of the drying cycle. To check the immersion heater will require you to pull out the washer from under the counter & to remove power from the appliance. Looking underneath the unit, remove a power lead from one side of the heater unit. Next, turn a volt/ohm meter to the highest ohms setting, turn it on, and touch the two leads together to make sure it's working. It should show zero no matter what ohms setting you have selected. Next touch each lead to each of two posts on the heater unit. It should show some resistance other than zero if it is good. If still zero, you will need to get a replacement heater from your fav local appliance store or go on-line and order it. Either way, make sure they have the full identification of your washer make/model. Let me know results?
Posted on Jan 02, 2010
  • 43501 Answers
SOURCE: no drying cycle on the electrolux dishlex 302 any
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Posted on Nov 10, 2010
SOURCE: Where can I get an Electrolux Dishlex DX302/403
Try this:
Posted on Feb 01, 2011
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Sep 03, 2014 | Electrolux Dishwashers
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA.
Nov 23, 2013 | Dishwashers
Dishlex dx 203 buzzer
solenoids that control water flow (taps) buzz when failing Check out the water in solenoid.
May 26, 2013 | Dishwashers
Hi, My Dishlex dishwasher DX 302WB ia showing 10
check this
1)blockage in boiler tank.(cleaned)
2)water pressure is less.(check solenoid filter)
if it's programmed in timer mode within the period it must reach the water level in the tank due to this also it may happen.
Jan 06, 2010 | Electrolux Dishwashers
I want to download a Dishlex DX103 dishwasher manual
want to know as this is my first dishlex dishwasher dx103. As there is no instruction manual being a rented property i want to know how to get solution on my problem. Was working last night but went to put a load on this morning but now have lights and thats it no cycle please help.....
Sep 19, 2009 | Electrolux Dishwashers
Dishlex dx 403 does not dry dishes - fan dry on red led
Ther have been a lot of complaints about the drying performance of these machines. One solution suggested by Electrolux is to use the "anti bacterial" wash mode, as this is a higher temperature wash, therefore dishes dry better. If you are using Eco wash or Quick wash, drying performance is not very good- Electrolux recommend leaving door ajar at end of cycle to improve drying. Also, ensure your Rinse Aid compartment is topped up, as Rinse Aid greatly improves drying performance.
-Please note: these dishwashers will not dry plastics and other items that do not hold the heat very well!!
-Also, you should be able to hear the drying fan running at the end of cycle- if not, then you may have faulty fan (uncommon), or control board (more common).
Good luck!!
Aug 12, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
I have a dx302. its not heating the water or drying.
My six year old Electolux Dishlex DX 403 dishwasher stopped heating the water. I found comments on the internet about burnt out solder joints in the control box. A friend opened the control box and found a blackened area on the back of the circuit board. Once the connection was re-soldered the water heated again. We also found that quite a few wires leading to the control box had overheated and the insulation had melted. Considering that this dishwasher was the top model from Electrolux at the time, I was not impressed. I had previously had a Vulcan Dishlex for almost 20 years.
Thanks to those people who previously posted information about this fault.
Feb 10, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex dishwasher
Theres a problem with the water level sensor or the main electronic control PCB.
Apr 21, 2006 | Electrolux 18 in. ESL4114 Slim-Line...
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
786 people viewed this question
Top Electrolux Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
