Question about Samsung CLX 3160fn All-In-One Printer
Internal error code
FM List.c 311 RO
Error code 311
The Error 311 indicates a communication error between the Mac and the printer. If you upgraded the Mac from Leopard to Snow Leopard, there could be older driver files for the iP4300 that are conflicting with the new driver. Therefore I would start your repair by trashing all of the Canon files.
The first step is to disconnect the USB cable between the printer and the Mac.
The next step is to delete the current printer queue for the iP4300. Open Print & Fax, select the iP4300 in the list and click the minus ( - ) button to remove the queue. You can now exit Print & Fax.
The third step is to remove the Canon files. These are located in HD > Library > Printer > Canon > BJPrinter. Select all the files inside this folder and trash them. Then empty the Trash and restart the Mac.
With the Mac restarted, you can now run the installer for the 10.6 driver you downloaded from the Canon web site. Ensure this driver is version 10.26.0.0.
Once the driver has been installed you can connect the iP4300 USB cable to the Mac again and open Print & Fax. If the install has worked, the printer should automatically appear in the Printers list (note that this can take several seconds). If the printer does not appear, click + to add and select the Default view. The iP4300 should appear in this view. Select it and click Add. You may get a prompt stating the printer is already installed. If so, cancel this install and try printing with the new iP4300 queue.
If the error message still occurs, then I would try another USB cable. They have been known to cause the 311 error.
Nov 09, 2015 | Office Equipment & Supplies
Erroe/fault 093-311
fault Code 093-311: Rotary Assembly Failure Solution : Power the Machine Off and On CAUTION: Wait at least 60 seconds between powering the machine off and then on again; otherwise, damage to the machine and the hard drive may occur.
  1. Press the power switch to the [O] (off) position.
    NOTE: The machine will remain on for approximately 10 seconds while storing files and preparing for shutdown, and then will power off completely.
  2. Wait 60 seconds, and then press the power switch to the ['] (on) position.
Jun 26, 2014 | Xerox WorkCentre 7232 VSE All-In-One Laser...
Error 929
Here is a website that has a list of the error codes:
http://creatives.ro/downloads/Errors_Xerox_DC252.pdf
Apr 03, 2013 | Xerox Phaser 7400DN Laser Printer
Message appears- internal error wer off/on FM_List. c 311 RO
May 03, 2011 | Samsung SCX-5530FN All-In-One Laser...
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
What is error code 311?
It looks as if error code 311 refers to printing using a computer with Mac OS X. I've found a solution on Canon's website that may help you if this is the operating system you are using: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=17160
Hope this helps.
Jul 10, 2009 | Canon Pixma MP480 All-In-One InkJet...
60.40 Error Message on HP Laserjet 5025 MFP printer
Hi
Welcome to Fixya
Have alook at the webpage by following this link:
http://servicelineat.ro/hplaserjetm5025.html
Scroll down the page for error listing. Unfortunately error 60.40 is not listed. It may help to ring HP service centre for a full error code list.
Hope this helps. Please don't forget to Rate this solution.
Thank you.
Feb 23, 2009 | Minolta EP1083 CS/PRO Copier
E020-0181
I don't know about the color copiers but here is a list of error codes, and their likely problems.
Looks like you will have to ge t a tech to fix it.
http://www.visualhawk.vcc.ro/canon_error_codes_en.html
Oct 23, 2007 | Canon CLC 1140 Copier
Samsung CLX 3160fn All-In-One Printer Logo
48 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
