Question about Toshiba Satellite M645 S4114 I5 2.66ghz 8gb 640gb Blu Ray Webcam Wifi
Blu-ray won't play - Toshiba Satellite M645 S4114 I5 2.66ghz 8gb 640gb Blu Ray Webcam Wifi
  • Toshiba Master
  • 27,725 Answers
If your Toshiba Satellite Pro isn't reading your DVD-ROM, it means that the DVD-ROM of your computer has been disabled. If your DVD-ROM drive has accidentally been disabled, enabling the DVD-ROM drive is quite a simple task to complete, even for individuals who have little to no experience working with computers.
Click on the "Start" menu and then "Control Panel." Click on "System and Maintenance" in the control panel. Click on "System." Click on the "Hardware" tab and then click "Device Manager." Click on the CD/DVD-ROM drive option and click on it so that it is highlighted. Right-click on the CD/DVD-ROM drive option, and then click "Properties." Click "Enable" in the properties menu and then click "OK." Restart your computer by clicking "Start" and then "Restart." Once your computer has booted, your Toshiba Satellite Pro DVD-ROM drive will be enabled. if still no joy
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it Hope this helps.
Posted on Jan 24, 2013
Blu ray player won't play or eject disc
If you want to eject the CD you need to look on the front of the Blu-Ray drive for a small hole, about the size of a pencil-lead. If you open a paper clip and insert it, it should pop the drive open for you.
Mar 06, 2013 | Televison & Video
Pioneer bdp 440 won't play region A blu ray
It may be the encoder that is going faulty in the unit i had the same problem with my dvd player after using different regional discs in them.
Feb 21, 2013 | Pioneer BDP-440 Blu-ray 3D Code Free DVD...
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
My blu ray player won't play the hunger games
Need more info. Does the player accept the disc? If so, do you hear the disc spinning inside? If not, what does the player do? Does it kick the disc back out? Will this player accept and play other discs?
Sep 10, 2012 | Sharp Aquos Bd-hp22u 1080p Blu-ray Disc...
Vizio vbr210 error 11000404 How do I update firmware to watch newer blu ray movies?
I had the same problem -- we even returned the disc and got a new one. Go to the Vizio site and download the firmware for your player. Put it on a USB stick and plug it into the player. Follow the onscreen instructions (basically just press OK). The entire process takes less than 5 minutes from download to finish.
The Hunger Games works perfectly now.
Aug 21, 2012 | Vizio VBR210 Blu-Ray Player
Lg bd650 won't play blu-ray but everything else.
The laser pickup unit [optical pickup unit] to your Blu-ray player is faulty. It will be very difficult to get from open electronic spare part market. Contact the nearest authorised service center for LG to get it repaired.
Jun 21, 2012 | LG BD650 BluRay Player
Sharp Blu-rAy player won't play Blu-ray discs but
Due to the nature of players often if the optical Pickup unit inside is dirty or failing Blu-rays will not play but DVD's will.
May 06, 2012 | Sharp Televison & Video
My toshiba BDXK100 won't play DVDs other than Blu-Ray
There may be a issue with the assembly, blu-ray plays with more precision and speed, for some reason it is not slowing down to play the regular DVD's may be a padder motor problem.
Mar 19, 2012 | Toshiba BDX2000 Blu-Ray Player
Toshiba Satellite M645 S4114 I5 2.66ghz 8gb 640gb Blu Ray Webcam Wifi Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
