Question about Wolf Range Kitchen Ranges
Wolf dual fuel range oven door it's locked
I tried to self clean the oven and it came up with ERR 01. Now the door is locked and it won't open.
josh1856
  • 105 Answers
SOURCE: Admiral electric range with self cleaning oven
There is an automatic lock feature on this unit that after 1 hour will unlock itself.
hope that helps!
Posted on Jan 30, 2008
  • 1314 Answers
SOURCE: Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Posted on Feb 12, 2008
  • 15 Answers
SOURCE: Oven won't lock and self clean.
Shut off the oven for at least a minute and turn it on, set the clock, and it worked. I had tried a short power cycle before and it didn't fix it. The extended power cycle did the trick.
Posted on May 02, 2008
SOURCE: Wolf oven self-clean error 01
Well, ours is working now. We called Wolf, they said the Error 01 indicated a problem with the latching mechanism (that locks the oven during self clean).
We called the local repair outfit (they've been here several times before working on this range), they ordered a latch mechanism and arrived today to install it. The tech this time had worked at an electronic company that I also worked for about 10 years ago (I'm an electrical engineer). So we had a good time talking about the old days and working on the range - I'm always curious about such things. We removed the latching mechanism - its an assembly with a motor and a couple of switches that are used to start and stop the motor. We tested the switches and motor using a meter and power cord. Seemed to be OK. The next thing would be the control board - which we had replaced about 3 years ago - under warranty. Before removing the control board we reinstalled the latch mechanism - and, of course, everything worked fine.
We were both a little dismayed about the quality of the assembly of the range - the wiring looks more like a rat's nest than the tidy routing that we'd like to see.
So, bottom line, neither of us knows what the problem was. Could have been a food particle lodged in the switching mechanism, an intermittent connection or ???.
One thing I noticed as we checked out both ovens: We put the small oven (the one that was having problems) in self clean for a couple of minutes - was OK. Then we turned it off and turned the larger oven to clean mode - when we did that, "OPP" appeared on the display. The tech said that was because the latch of the smaller oven was not in its stop position yet. We gave it a few more seconds then tried clean mode on the other oven and it was fine. I mention that because OPP appeared on the small oven once or twice when we (my wife and I) were initially trying to figure out what the problem was. There's probably a hint in there somewhere as to what the real problem was.
At any rate, its working again ($115 later) but I'm not real confident that it will continue. Next time, I'll open it up myself (not recommended). <g>.
Posted on Nov 07, 2008
Boogan
SOURCE: Viking range self cleaning not working - door locked
This is a more common problem than revealed by Viking.
Heres how I an "amature" fixed it.
Top center of many viking ovens have slots. With a small flashlight look into the center slots. "Its HARD to see" Look for something
shiney thats the latch/hook everything else will be dark.
I used a shish ka bab skwer. You need something like that or maybe an ice pick. Knives screwdrivers and things like that will
damage the face of the oven and then after opeining it you will forever feel bad about marring that very expensive unit.
Take the pick and with the flashlight guide it to the shiney part.
Once touching push to the LEFT. Keep trying as the pick will slip
many times. The latch should have no resistance if you can get on it.
Once open you can try and reset the hook to its open position.
Mine would not reset and prevented the door from closing.
This is now another fix. To keep the hook held to the open position. E mail me for how I jury rigged this part.
Mexvillas@aol.com
I have the hook held open now and will never be able to use the self clean function again. But thats better for me than a open wallet fix for the repair man and then wonder when it will happen again. To repeat. This is a known problem with Viking ovens.
Cheers
Posted on Apr 08, 2009
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
Oven door won unlock
I HAVE A 10 YEAR OLD OVEN RANGE. SELF CLEANING IS IN THE LOCKED POSITION. I UNPLUG THE RANGE FOR 30 MIN THE DOOR IS STILL LOCKED
Jan 08, 2014 | Electrolux 30" Self-Cleaning Freestanding...
Oven door won't lock, self clean won't start
this is a door lock error , you will need to replace
Feb 20, 2013 | Kitchen Ranges
Oven lite won't go off and when turn on self cleaning it says door
The door switch has gone bad. This will keep the oven light on and the self clean won't work because it thinks the door is open.
Dec 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
Started to bake an item, so I preheated the oven and started to cook item when all of a sudden an error code came up and stopped the oven from baking any longer. THE CODE( F95 ERR) came up and shut the...
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 23, 2010 | Kenmore 47153 Stainless Steel Dual Fuel...
I cant get my viking 30inch electric range to self clean. it has a self clean spot on the knob and on the temperature knob but when both in place nothing happens.
You might need to lock the oven door to get the self clean to go on. My stove had a lever which locked the oven door when you pushed it sideways. It was in the middle above the oven door, in the gap... Hope this helps!
May 06, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
How do you use the self cleaning option for Kenmore dual fuel ove
Simply press the "Clean" button and set a time (Hi or 4hrs is best) it will the lock the door and burn everything inside. If you have silver colored shelfs remove them fist. After its done and has cooled wipe out the ash that has collected in the bottom of the oven.
Dec 27, 2008 | Kenmore 75503 Stainless Steel Dual Fuel...
Oven door during self cleaning mode
hi there sounds like a faulty door interlock!!!!
have you tried just leaving the cooker on self clean as some models will lock them selfs.
Feb 29, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
Top Wolf Range Kitchen Ranges Experts
Ismael Rodriguez...
Dan Webster
Dan Webster
Rick Davis
Rick Davis
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
