Question about GE GTS22KCP Top Freezer Refrigerator
Freezer is working bottom is warm - GE GTS22KCP Top Freezer Refrigerator
Freezer is working, refrigerator is warm
You probably have a defrost issue with the freezer. Cold air is passed to the refrigerator section from the freezer, when the freezer does not defrost air flow to the refrigerator is eliminated causing the refrigerator to warm up. Check for icing on the back wall of the freezer. If no ice on back of freezer, check the damper assembly going to the refrigerator section.
May 26, 2015 | Refrigerators
Kenmore 596.73503201 frig warm, freezer working
Check your duct from freezer section is open if it is check that fan is running ,if it's not the fan is faulty and needs to be replaced
Jan 10, 2014 | Kenmore 73503 Stainless Steel Bottom...
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Jenn-Air Jrsd 249t top is warm... bottom freezing
Uncertain as to whether this is a "freezer at top or bottom" model? Make certain that temperature control settings are approximately at the one-half way for both the freezer and fresh food compartments. If freezer at bottom, you may have a defrost component issue (defrost thermostat or heater). If so, contact an appliance service company.
Feb 10, 2010 | Refrigerators
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
My amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Nov 04, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Sears Kenmore bottom freezer/refrig #68142model
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Jul 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
GE GTS22KCP Top Freezer Refrigerator Logo
13 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
