Question about Amana Tandem 7300 Washer and Dryer Stack Assembly Kit 8572546
I HAVE AN AMANA TANDEM 7300 IT STARTS THEN STOPS AND BEGINS BEEPING DOOR WONT UNLOCK TO GET MY CLOTHES OUT WHAT DO I DO???
  • Amana Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 24, 2013
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: amana tandem 7300 stopped ,door is locked wash
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Posted on Nov 28, 2010
Amana tandem 7300 washer hums but won't spin. Stopped with clothes and water in it.
If you would drain the water out with a hose (siphon it out) and remove the wet clothes, then look underneath the machine and see if you have a drive fan-belt, you may find it broken or slipping.
A very few machines have a drive shaft with a coupling instead.
God bless your efforts.
Jan 02, 2017 | Amana Washing Machines
Why is my Amanda 7300 tandem washing machine not doing the wash cycle? It stops after water has filled and stats to beep 3 times in intervals....
Sometimes this can happen when the power button does not return completely when pressed in. My cheap & cheerful solution was to use a bit of Blu-Tak on the button, so I could pull it all the way out.
Sep 23, 2016 | Amana Tandem 7300 Washer and Dryer Stack...
My amana tandem 7300 will not turn on any cycle it will go back to wash but does not turn on it just beeps please help if u can
It may think the door is open, front load machines will not proceed to fill if they cannot sense a locked door...
Apr 22, 2016 | Amana Washing Machines
Is there a DIY solution to my Amana washers problem?
It's a computer too. discommect it from power for 15 minutes and re-plug it. start initial setup again. Here is the link to the manual.
https://www.manualowl.com/m/Amana/NFW7300WW/Manual/206242tj3x46
Oct 02, 2015 | Amana Washing Machines
I have an Amana Tandem 7300 and when it cycles, gray powder is everywhere and some of our clothes have been ripped up while being washed. Please tell me this is an easy fix which I can do myself!!
I have the same problem with my 7300. The grey material is actually the door gasket being rubbed and abraded away. Mine finally wore through the gasket entirely and had to be replaced. I have yet to find out why, or find anyone who knows why.
Jan 03, 2012 | Amana FXDX - FXDXI Dyna Super Glide Sport...
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Nov 28, 2010 | Amana Washing Machines
Amana Tandem 7300 Washer and Dryer Stack Assembly Kit 8572546 Logo
1,808 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
