Question about Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB DESKTOP (PCP418DELL)
Dell optiplex p4 1.8ghz: RAM
Just bought one of these 2nd hand.
It is running XP Pro, but only has 256MB of RAM installed.
Not being a techie, can somebody please answer these questions:
1. WHAT type of RAM chips does it take? (DRAMM etc)
2. What is the maximum amount of RAM I can have. (Chip size per socket), including overall total.
  • 1 more comment
  • zorch15 Jan 28, 2009
    All I can see is: Dimension 2350.
    Does that help.
    Thnx guys.
    All I need to know.
    Thnx again,
  • Dreamornaut
    Dreamornaut May 11, 2010
    Would need to know the specific model number. It should be something like Optiplex 160 or GX240.
  • 34 Answers
I have found your solution is in this website if you are not able to read it from here:
Microprocessor type
Intel® Pentium® 4 that runs at 1.80, 2.00, 2.40, or 2.50 GHz internally and 400 MHz externally;
Intel Celeron® that runs at 1.70, 2.00, 2.10, 2.20, or 2.30 GHz internally and 400 MHz externally.
NOTE: Microprocessor offerings vary by country.
L1 cache
8 KB first-level (Pentium 4); 32 KB (16-KB data cache; 16-KB instruction cache) (Celeron).
L2 cache
256- or 512-KB (displayed in the system setup program) pipelined-burst, eight-way set associative, write-back SRAM (Pentium 4);
128-KB SRAM that resides in the processor's core. The L2 cache runs at the processor's internal clock speed (Celeron).
System Information
System chip set
Intel 845GL
DMA channels
Interrupt levels
24 APIC mode
System BIOS chip
2 Mb (256 KB)
System clock
400-MHz data rate
Expansion Bus
Bus types
Bus speed
PCI: 33 MHz
PCI connectors
PCI connector size
120 pins
PCI connector data width
32 bits
Memory connectors
Memory capacities
128-, 256-, or 512-MB
Minimum memory
128 MB shared DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
1 GB
Memory type
PC2100 (266-MHz) DDR SDRAM
Externally accessible
two 5.25-inch bays
one 3.5-inch bay
Internally accessible
one bay for 1-inch–high IDE hard drive
Ports and Connectors
Externally accessible:
9-pin connector; 16550C-compatible
25-hole connector (bidirectional)
15-hole connector
6-pin mini-DIN connector
two front-panel and four back-panel USB 2.0–compliant connectors
RJ-45 connector
three back miniature connectors for line-in, line-out, and microphone
one front miniature connector for line-out
Internally accessible:
Primary IDE channel
40-pin connector on PCI local bus
Secondary IDE channel
Floppy drive
34-pin connector
Posted on Jan 28, 2009
  • 1,901 Answers
Best and easiest thing to do is go to and run a scan of your computer. It will tell you what you have, how much it will hold, and what kind of modules.
Yes, it's safe.
Thanks for using Fixya!
If you have any trouble, comment back.
My Dell optiplex Gx240 wont boot after installing new ram . It saids stopped at check point vcls.
The new RAM has a problem. Insert one at a time and power up. You may have a bad RAM stick.
Oct 26, 2012 | Dell OPTIPLEX GX240 P4 1.7GHz 256MB 20GB...
I have a Tecra 8200 bought as used fitted with 256MB of ram. If I buy an extra 256MB which brings the total to the maximum allowed of 512MB is it likely that I will need to upgrade the bios to allow the...
This laptop came with 128mb ram, you can safely install 2 sticks of 256mb for a maximum of 512mb with no bios update.
You need pc100 sodimms.
Amazon or ebay will be the best bet as this memory is expensive now from a retailer.
I found 256mb sticks for under $10 buy it now on ebay
Jul 08, 2010 | Toshiba Tecra 8200 Notebook
Why does a 1GB DDR PC2700 333MHz RAM show as 32Mb in a Dell Optiplex GX260.I want to upgrade from the existing 256Mb and hopefully run the two RAM together
It is because this computer only supports 200 or 266 MHZ SDRAM modules. The one that you are trying to install is not compatible.
Please see this link for reference
Optiplex Specs
Feb 01, 2010 | Dell OptiPlex GX260 PC Desktop
Booting Problems With Dell Optiplex gx270 and gx260
Does anything show up on the screen when you access your BIOS?
Have you tried a fresh install?
Are there two video adapters installed (one integrated and the other in the AGP slot?
Oct 14, 2009 | Dell OptiPlex GX270 PC Desktop
I have a Dell Optiplex GX270 running on windows XP pro. It has 2MB RAM and 80GB hard disc drive. When I checked to see if I could run Windows Vista Ultimate, the checker said I could, but might need to...
You'll need to have at least the following specs to run vista comfortable; 1 or 2 Ghz processor 1 or 2 GB RAM Video : AGP with 256mb or more cache Yoy might also have to consider changing your power supply.
Aug 13, 2009 | Dell Optiplex GX270
Slow System
Upgrade your system RAM.It will improve your system performance.
Apr 03, 2009 | Dell OptiPlex GX110 PC Desktop
Windows XP won't boot with "CREATIVE SOLUTIONS" PC
That machine is too underpowared to run xp pro.
Windows XP Media Center Edition
1.6 GHz CPU, 256MB Ram, and DirectX 9 hardware-accelerated GPU
you may get it to run but it is going to be dead slow. you will be waiting forever to load any apps with a processor under a gig, and less than 512 mhz of memory, it may work for emulation, but that's even questionable. I don't want to aggrvate you but that config is a decade old. Vista for instance needs at least 2 gigs of ram and a dualcore to run right. sorry bud, if you are dead set on it, the only thing you coula do is juice up the memory, to whatever the board is rated to take, or I would run windows 98, peace
Feb 03, 2009 | Dell XPS™ 600 PC Desktop
Multiple Boot on a Dell Inspiron Laptop
Invest in a couple USB drives and install the other os's on them. before you boot up plug in the apropriate drive and boot from it. Thats less complicated and painful to me
please, Let me know :)
Dec 24, 2008 | Dell Inspiron 6400 Notebook
OptiPlex GX270 mini tower
Remove the 256mb memory and insert the 512mb memory in slot1 and see whether it works. Please note that the memory needs to be in pairs.
I think the GX260 is mini tower has two different moles
1) PC3200 compatible with memory - 184 Pin DDR3200 400MHz
2) PC2700 compatible with memory -184 Pin DDR2700 333MHz
Please enter the service tag on and find the manual and the right memory for your PC
All the best!
Dec 17, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
I have a compaq with a 90 gig hard drive, at presenr I am running 384 bytes of RAM. How much will this PC safely handle?
Depends! The amount of RAM has nothing to do with capacity of the hard drive. If your motherboard is a P3, it probably has to memory slots that will handle 256mb each (512 total). It sounds like you have a 128mm chip and a 256mb chip installed now. I won't even attempt to run XP with less than 256mb of RAM. You can run XP with 128mb, but not very well. With Windows XP SP2, you will have to have at least 256MB. Most P4 or newer computers use DDR RAM wich can be bought at larger capacity (ie 1000MB).
Apr 18, 2008 | Computers & Internet
Computers & Internet Logo
450 people viewed this question
Alun Cox
