Question about Arris Vanguard 6455 Router
Vanguard 6455: double configuration.
A Vanguard 6455 router has two ETH ports with it's own IPs. While connecting to the first the device shows a banner with "Product Type: Vanguard 300" and "Vanguard 6455" while connecting to the second. It was found that at one device two different cofgurations are installed. The second one works properly and the "Vanguard 300 configuration" is set up un wrongly and it is not active. Moreover a manager's password for this configuration was lost.
How can the wrong configuration be deleted without hard-reset? Or is there any default managers password for the Vanguard?
  • jsnetman8 Feb 25, 2009
    Thanks a lot! Unfortunately I didn't try your suggestion because we weren't sure whether another config would still exist after the reset. Maybe another month will allow us to make some experiments with our equipment.
    Thank you for your help!
When u reboot your router, at POST type ZAP command.. by this you will reset your password as well as your configuration.
try this and let me know ... wht happen??????
Posted on Jan 30, 2009
Change ip address
The IP address is configured through your DHCP server in your router. You're going to have to either look in your router for connected devices or use a tool like netscan.exe (free) to find the assigned IPs in your network, If you don't have too many connected devices, you can keep putting the IPs that are there into your web browser until the device page comes up. They SHOULD HAVE put a reset button on this thing, but they didn't.
Aug 17, 2013 | D-Link DP 301P (DP-301P) Print Server
How to do 6455 "Node to Node download" Thanks a
tai sao motorola khong chup hinh duoc mong cac ban giai dap dum` em
Aug 14, 2013 | Arris Vanguard 6455 Router
I can't connect my router model f7d1301v1
Connect the IPS modem to yellow port. Then connect PC to any other port. Test if internet is available on PC. Installing Belkin Software will also show if DHCP devices show up. The default IP should be 192.168.2.1 then new devices will similar IPs. Plus check if your other wireless devices has WPS. It is a self discovery option.
Aug 28, 2012 | Belkin Connect N150 Wireless N Router
I have problems with my vanguard motorola 6455 "error need coldload" i need help urgent
In main menu type (7.5.y) and the router will be reboot, you'll loose the data and configuration. Re-imagine it, Re-configure it and you'll ready to use your vanguard
Mar 30, 2011 | Arris Vanguard 6455 Router
I need the line command set to configurate a Motorola Vanguard 6455, thank a lot...
Open command propmt, type there ipconfig and look for default gateway. Take note of the default gateway numbers and type that on the address bar of your IE browser. There you can setup the device.
Jun 09, 2009 | Arris Vanguard 6455 Router
Link 1 lit up and no more connection to internet
You may have been hit by lightning or power surge which knocked out one or 2 ports. If the WAN port is out you may still be able to use your router as a hub provided your modem can be configured as a router (many newer ones can) . Connect one of your working LAN ports to the modem and others to your computers.
May 22, 2009 | D-Link DI 514 Wireless Router (DI-514)
Vanguard 6455 router lost password
in my experience, any router where you cannot access it, you will have to do a factory reset. Generally there is the small paperclip size button in the back that you press and hold for 10 seconds while the router is on. after that, you release and unplug the router. Press the small button, plug in the router, and hold it for about 20 seconds. Sadly, I have found this my most common and best answer...
Dec 19, 2008 | Arris Vanguard 6455 Router
Connection problem
If I understand what you're saying, you need a router.
See here for an explanation"
http://compnetworking.about.com/od/homenetworkhardware/f/routervsswitch.htm
Nov 04, 2007 | Computers & Internet
Restarting device
Generally Yes, when any Systems Settings are "Updated" usually one must reboot any system to cause the system to "Write" and then recognise the new values.
Apr 05, 2007 | Arris Vanguard 6455 Router
Arris Vanguard 6455 Router Logo
492 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
