My hotpoint aquarius wmf 945 trips off when switched on . Blows my downstairs sockets. 18 months old. When drain pump is disconnected it will start. Any answers please.
  • 209 Answers
SOURCE: Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Posted on Oct 03, 2007
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
  • 193 Answers
SOURCE: h20 error on hotpoint
Lift the lid and check that clear hose is connected to the pressure switch.
Posted on Nov 02, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius wmf 740 has error code f5 - what does it mean?
I think you mean F05, in which case it means that the pressure switch is jammed on full.
You need to remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well, and look inside the pump.
This should solve your problem.
Posted on Nov 28, 2009
SOURCE: Hotpoint Aquarius condenser dryer model no. TCL770
we had this, and it turned out to be the plug getting damp at the back of the dryer due to inadequate ventilation at the back of the dryer...we pulled the dryer away from the wall slightly, allowed the plug to dry out for a few days and the problem was solved.
Posted on Mar 22, 2010
I have just bought and installed a new Bosch WIS28440GB washing machine. Works fine until it starts to drain when it starts to pump water but then trips the electrics. The drain is connected to an...
Bosch WIS28440GB washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Sep 17, 2011 | Hotpoint Aquarius WD63 Front Load...
My hotpoint aquarius wdl540 keeps tripping the switch on the main fuse for the kitchen plug sockets
hello, the reason for this because theres a dead short inside washer or the socket may have a loose wire check all the earth wires inside the washer and the sockets get back to me if you still have trouble
regards
shaun
Jan 03, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Sep 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing machine says door problem even though door is shut hotpoint aquarius wmf 740
The door switch is no longer making contact internally or a wire has broken r disconnected. I would verify this with a test meter and replace the switch. Eric
Sep 13, 2009 | Washing Machines
Flashing lights and trips the electric
Are you around when the breaker trips? It almost seems as though an electrical connection is getting wet. Especially if it won't let you reset the breaker. Another reason for not letting you reset the breaker could be an overload that tripped but that to me would be within the machine, it shouldn't trip at the panel. You get pull the machine apart and check for these things. Look for and wetness or wire connections being crossed, anything like that. Something at the spin cycle is shorting out and tripping out your breaker. Also is your dryer circuit properly sized (30AMP Breaker with 10/3 wire)?
May 26, 2009 | Hotpoint Aquarius WF220 Front Load Washer
When turn washing machine on about 5 - 10 minutes into cycle sets trip switch off and no power. Happens everytime try to use it - tried different sockets - checked fuse. We have hotpoint aquarius extra...
heater probably down to earth and only solution is to check. to test, remove wires from heater, tape them up for safety then start cycle and see if fault still happens
Jun 29, 2008 | Hotpoint Washing Machines
HOTPOINT aquarius WF541G
most likely suspect is the heater. undo wires from heater and see if fault persists. if not, heater is down to earth and will have to be replaced.
another possibility is a leak causing some of the wiring to be wet
Jun 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
