Quiet right channel when playing pre-recorded tape.
The product is a Denon DR-M12HX stereo cassette tape deck. When playing pre-recorded tapes, I noticed that the right channel was quieter and very occasionally and briefly crackle and become louder. I tried adjusting the azimuth head, but it was difficult with the nut/bolt design rather than a phillips head screw as shown in my fix-it-yourself book. I never was able to get the right channel as loud as the left. I bought a cleaning/demagnitizing kit which may have helped a little, but the channels are not the same bass/treble-wise and the left still louder. The head looks to the naked eye like it's straight. Any ideas on what I could try next? Does it sound like I need a new head altogether? Thanks for any help you can provide.
  • Audio Player... Master
  • 5,259 Answers
With the deck in play mode put your finger on the imput of the channel that is low. If it buzzers the same as the other then you may have a faulty head. If it does not there is something wrong in the amp stages of the deck. You can also reverse the leads from the head and if the sound goes down on the other channel it is the head. Try doing it where the leads join with the PC Board, it will be less messing than at the head itself.
Posted on Feb 02, 2009
How can I use a hand held stereo microphone to record via a Denon F101 tape deck
You really need to include all brand and model number info for this question.
Feb 03, 2015 | Denon Audio Players & Recorders
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
When I recorded a cassette, the problem is the stereo is going to mono either left or right channel, and also have low volume problem during recording.
This sounds like an recording pre-amp problem. Anything common to both channels problem faults are always connected with a device that has both channels going in and out of it. In this case I suspect a recording pre-amp IC.
Jul 07, 2010 | JVC TD-W254 Single Cassette Deck
Won't record and play sounds muffled
Muffled sound is either damaged media (is it mostly the Left Channel? Multiple tapes or not?) or dirty Playback Head. Clean the heads and transport.
Please define better what "won't record" means. Tapes to be recorded need to have the little tab in the corner of the cassette shell present to allow the machine to enter record mode.
Feb 19, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Denon Stereo audio cassette deck DR-M30HX traction prob thin tape
Belts for decks are universal, there are plenty of places on the web selling them. Parts for a Denon from 25 years ago is another matter. However I think you might need only the belts, as the longer tapes speed problems suggest that it's the load that's causing the belts to struggle. All you need to do is measure the diameter of any belts for replacement. HOWEVER before you remove them make a note, or photographer, how and where they fit.
Use Servisiol Video 40 to clean the rollers and head.
Feb 01, 2010 | Audio Players & Recorders
Reorded tapes only play out one speaker
check your cables to the units channel that doesn't work, for breaks. Does the cassette player play back a pre-recorded tape okay? if it doesn't there might be a internal fault.
Check the wires to the tape head to see if one is off.
Jun 06, 2009 | Kenwood CT-201 Cassette Player Single Dual...
Denon DRW-585 dual-cassette deck makes clicking sound
There is an outside chance your tape cassett has a static charge. Tape in plastic case of cassette can build up significant electrical static which can partially discharge as tape is run. It can sound like random thumps, ticks, pops ect. Wrap cassette in a damp (not dripping wet) cloth, for several hours, then try again. This can also happen to the reels and drive rollers of the deck
Apr 04, 2008 | Audio Players & Recorders
193 people viewed this question
 Grubhead
Grubhead
