Question about ASUS P5VDC-X Motherboard
No sound out put
Audio driver loaded ok,. motherboard connector ok, can't listen to any sound. sound control panel shows orange colour.
    President:
  • 2,110 Answers
Http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5VDC-X
here u can download audio driver and install it...
Posted on Jan 28, 2009
No sound coming from my speakers. I went into the control panel and and it showed there wasn't a multi audio controller. I restored to a previous date and it fixed that issue. Or I assume it did since the...
Check the following,
  • Speakers, connecting cables and Sound Card are working fine by connecting to another computer.
  • OR
  • If the connection ok increase your volume and open the cable from the pc.
    Now you will touch the stereo jack, can you can listen a sound when touch the jack. If you will not get any sound, think there is the problem in your amplifier or audio system has not any voltage. To confirm the voltage check by multi miter or can go any local Technician .If the voltage is ok, think your sound system defected and should go to Technician.
  • If your sound system is ok
  • Speaker Cable connect to an audio port (Audio/Video port in system box).
  • Ensure Volume is not in MUTE / Low (in Volume Controller).
  • Audio drivers have installed.
  • To confirm follow next step or ROLL BACK THE DRIVER
http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx For another check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers). If you need more information, reply me soon.
Thanks
Feb 20, 2011 | Audio Players & Recorders
I can not get any sound.
Start your PC and press Dell/F2/F10 for setup BIOS.
Enable on board audio.
F10> hit .
When the problem will be same ,do another step.
Follow bellow.
  • OR
• Go to Start>
• Control panel>
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers). Hope it will help you.
Dec 31, 2010 | ASUS P5GC-MX/1333 Motherboard
Dell(intel motherboard High Audio Defination sound)power showing yellow colour instead of green for display.It is not displaying at all, power supply ok, ram ok, cmos, ok, motherboard ok, audio sound no...
control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 28, 2010 | Intel BIOSTAR Mainboard Support processor...
Dear sir, i have motherboard 945 i did install motherboard drivers, but sound does not work, in device manager, it shows that hardware is ok
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
hope this helps
Dec 07, 2010 | Intel Motherboard
I have Acer aspire 5741, OS: win7. The problem is that when I plug in headphones or 2.1 speakers the sound get worsed and I hardly could hear anything. I've insalled latest realtek sound drivers but that...
hi Dzhamal23.
you may need to setup the sound for your speakers.
First Check if your headphones work on rear audio panel or not. If they work there then you need to set your Realtek HD Audio to recognise your headphones. Do this:
Open Realtek HD Audio Manager from control panel or from notification area icon(a brown coloured speaker).
On the dialog box just below the close button there is written 'Device Advanced Settings' (no need to change the settings) and below this there is a Folder icon which shows tooltip text Connector Settings when you hover your mouse over it.
Click open the Dialog Connector Settings.
Tick the checkbox against Disable front panel jack detection and click OK.
i also found this on the internet.
So I have contacted Acer and I isolated the issue they dont support the issue but I have found through research that the motherboard has a problem relating to the headphone jack I have seen then listed for sale on Ebay with broken audio jacks I used a usb headphone set and received clear sound and after removing the third party software the speakers are sounding good too... if you have a nice set of mm headphones then you can buy an adapter that converts usb to mm so you can use them this way and that will prevent having to replace the faulty motherboard/audio jack
or go to this link and it will give you step by step on what to try out.
Fix Windows 7 Headphone Not Working Issue Driver Easy
Dec 01, 2017 | Acer (54.AA806.001) Sound Card
No sound when i put in cd or dvd was working ok untill my computer crashed
check the following
Microsoft Volume Control or your mixer program mute options and volume sliders.
Connect headphones to the stereo phone jack on your CD-ROM drive’s front panel; adjust the volume control settings on the drive. If there is sound from your headphones, check the CD audio cable connection from the CD-ROM drive to the audio card.
Ensure the speakers are properly connected to the audio card’s output connector.
hope this can help
goodluck
JABEMS
Nov 13, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Sound drivers
realtek sound driver of D945GC NOT LOADING SHOWING FAILED IN XP FORMATING.PLEASE HELP.
Jul 09, 2009 | Intel D945GCL Motherboard
How to get sound volume controler
1. Install the Sound Drivers.
2. Green colour connector is Audio out put.
3. go to control panel , check the sound selection
Nov 22, 2008 | Fujitsu Scenic P ( LKN:GBR-668402-049) PC...
Problem in installing audio driver of DG31PR with window XP sp-2
AUD_allOS_5745_PV_RTL from Intel, and MS Service pacj 3 fixed this problem for me.
Nov 12, 2008 | Intel DG31PR Motherboard
SOUND PROBLEM
* i think you haven't register o.s
* if o.s is register it will not support some drivers to be installed
Jun 19, 2008 | ASUS A8V-VM Motherboard
ASUS P5VDC-X Motherboard Logo
121 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
