Question about Cisco WAP321 IEEE 802.11n 300 Mbps Wireless Access Point
Cisco WAP321 Where do you find the pin number?
Got no internet connection
is it pin code:
then go to your server adress (in my country it is 192.168......)
check there u will get your pin number
Dec 02, 2012 | Computers & Internet
Default password for a Cisco SG200-26? cisco, cisco do not work .. ??
I had the same issue after what I thought was a succesful reset. It turns out I hadn't reset the switch completely. There is a reset pin hole next to the power switch. Hold it in with a paper clip for at least 30 seconds. ( I was holding in the power button for 30 seconds.)Then you can use the cisco admin and cisco for password defaults. Hope this helps someone in the future since I spent WAY TOO MUCH TIME on it :)
Oct 27, 2012 | Cisco SG200-26 24 10/100/1000 Ports,...
Need to convert a Power Supply CISCO 34-0873-01 to work stand alone??
These should use a standard ATX pinout. Use the big 24 pin moles connector to bridge pin 14 to 15. http://www.techpowerup.com/articles/other/22
Sep 30, 2012 | Sony Lot Of 2 - Cisco Catalyst 4000 Series...
My girlfriend put in the pin number of my wireless into her PC and it renamed my wireless network and I can not longer secure my wireless network. I have a Mac and I do not know how to reconfigure it to...
On her PC, connect again to your router.
Click Start
Click Run
Type CMD
Press ENTER
Type IPCONFIG
Press ENTER
Look for output like: Default Gateway ... 192.168.123.456
(Your numbers may vary!)
Start Internet Explorer
Type http://192.168.123.456
Login to the CISCO router's web-interface.
Click "Restore Factory Defaults".
The router will restart itself, and you will need to reconfigure it.
Jul 30, 2011 | Cisco - Linksys Wireless-n Home Router -...
Where is my pin number for wrv200
Where you can locate the pin number in most cases. You enter your Routers main source IP whether 192.168.2.1 or 1.1 whichever the case may be. Go into your wireless setting, there you will see a choice to log in manually or with push button scanning or something along those lines. Anyways if you deselect the manual and use the scanning option, you will see your pin for the router in the information of this page.. Hope this helps you out.
Feb 15, 2011 | Cisco WRV200 Wireless Router
Reset my Cisco AIR-AP1242AG-N-K9 but still can't access the control panel using a console calbe and laptop. Using Cisco Cisco as user name and password. Note when typing the password nothing appears in...
Hmmm..., I assume you are using Windows..... Try just going to the Network, see if you router shows up if so.... Click on it... It should ask for a pin type in the pin that usually can be found on the bottom of your router... If not reset to factory defaults and in your broswer type in your IP address, do not use autoconfiguration.... On all Linksys routers the default username is admin (with the password left empty) from there you can set your password and configure your router for use.... Hope this helps ;)
Jan 05, 2011 | Cisco Aironet® 1242AG (AIR-AP1242AG-N-K9)...
What are some wifi passwords
The default passwords for cisco models can be found here: http://hubpages.com/hub/CISCO-Router-Password-Default-Password-for-CISCO-Router
Nov 28, 2010 | Cisco (WS-X3011) Router
No power to cisco 5505 ASA
http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
From the US, you can call: 1.800.553.2447
From there, Cisco will be able to tell you what your warranty status is by the device's serial number, and can also provide you with a quote if your warranty has expired.
Oct 08, 2008 | Cisco ASA 5500 Firewall
Cisco WAP321 IEEE 802.11n 300 Mbps Wireless Access Point Logo
27 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
