Question about Onkyo TX-8511 Receiver
Powered Or Unpowered Subwoofers For Onkyo TX-8511
Should I connect powered or unpowered subwoofers to my Onkyo TX-8511 stereo receiver?
Also, I'm assuming I can just run speaker wire from each speaker to the subwoofers. Is that correct?
Thanks,
-Greg
    Scholar:
  • 93 Answers
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
How to connect Sony dvd player to onkyo TX-8511 receiver
The TX-8511 is an older AV receiver with only composite video inputs. Your DVD player may not provide this type of output as it's not capable of HD video. If your dvd player has a composite output with a Red, White & Yellow set of outputs, that will connect into the Video 2 inputs on the receiver. Your TV will need to connect up to the Video2 or Monitor output. You'll need a set of composite video cables with the red-white & yellow RCA type plugs.
Here is a link to the manual for this receiver:
Receivers Receiver Stereo Receiver AVR TX 8511 Onkyo USA
Mar 13, 2015 | Onkyo TX-8511 Receiver
How to hook up emerson subwoofer sw 03
For powered sub :If your receiver has a sub woofer output on female RCA plug, that is the way to go. If no output you will have to get a speaker line to line output converter to then connect to your subwoofer amp input.
Unpowered sub - just hook up across the speaker terminals for each channel making sure that you hook it up in phase.
Mar 14, 2014 | Audio Players & Recorders
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
Hooking up our onkyo ht-r340 the subwoofer has 2 line outs left and right back of amp has one subwoofer outlet. what to do
First would be to name the subwoofer so we can look at its "Line OUT's". The IN's would be more important as far as ITS function goes. I'm sure a manual exists for the unidentified subwoofer.
http://g-ecx.images-amazon.com/images/G/01/electronics/detail-page/htr340large.jpg
This receiver has direct subwoofer amplifer for a passive (unpowered) subwoofer as well as a Subwoofer Line Out for controlling an active (powered) subwoofer amp.
Jul 24, 2011 | Onkyo Audio Players & Recorders
How do I connect my Samsung Model un46b8000xf led to onkyo receiv
Use the TOSLINK - the optical/digital connector on both devices.
Jul 07, 2010 | Onkyo TX-8511 Receiver
I must have hit some buttons on the remote unintentionally - all of a sudden I lost the sound out of the left speakers on my Onkyo TX-8511
Reverse left and right speakers at back of unit
to verify if a speaker/wire problem. Also check
all functions for same problem!
Jan 30, 2010 | Onkyo TX-8511 Receiver
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
Onkyo TX-8511 Receiver Logo
1,305 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
