My symbol ds9808 scanner scans fine but does not beep with each scan
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
  • 4 Answers
SOURCE: SYMBOL LS1902T1000
I'm sure it will help you
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5093002apdf&sliceId=&dialogID=49522119&stateId=1%200%2049518470
Posted on Apr 28, 2008
thesuperdude
  • 97 Answers
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Posted on Mar 26, 2009
  • 31 Answers
SOURCE: Windows Mobile Symbol Find WLAN error
Warm boot the MC55 if that doesn't help then cold boot it, if that doesn't help then reload the Operating system, if that doesn't fix it then send it back to Motorola for a warranty repair.
Posted on Jun 30, 2009
Yogger
  • 117 Answers
SOURCE: My symbol barcode scanner beeps 4 time while I try
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Posted on Sep 08, 2010
123scan - leanguage problem
http://www.motorola.com/web/Business/Products/Bar%20Code%20Scanning/Bar%20Code%20Scanners/General%20Purpose%20Scanners/DS9808/_Documents/_Static%20files/SYMBOL%20DS9808%20Quick%20Start%20Guide.pdf
there are bar codes for the country you are in underneth programing bar codes 3rd one down in the 3rd colom
if this helps you out pleazse take a moment to rate this. anything else i could assist you with?
Jan 14, 2013 | Symbol DS9808-SR00007NNWR - Motorola...
Symbol DS9808 will not scan barcode
Hello Dbird,
the scanner has several barcode types enabled by default. Other type or lengths must be activated with an programming barcode from the Programm Reference Guide for DS9808.
Please check which kind of barcode are you using. Download the Program Reference Guide from support.symbol.com Scan the barcodes from the chapter Symbologies
Dec 02, 2010 | Zebra Symbol DS9808 Barcode Scanner...
I have a barcode scanner Symbol S/N M1J82M51E. When scanning the item barcode it makes very low volume. How to increase the bipping scanning volume for the Symbol Scanner?
1. Press and hold the trigger for an extended period of time (approximately 5 seconds). The scanner cycles through three settings (Low, Medium, High) emitting a 2-beep tone at each setting.
2. To select a particular setting, release the trigger after you hear the desired 2-beep tone.
Sep 18, 2010 | Symbol LS9208 Hands Free Barcode Scanner
LS3070 (ls3070-i000a) Handheld: My scanner stopped scanning. It beeps four times. ...
The four times beep means that there is an problem in the connection to the PC, please check the cables and configuration.
May 18, 2010 | Symbol LS3070 (ls3070-i000a) Handheld
3 Beeps after trying to scan
If you are receiving three quick beeps (all the same tone) before a scan the battery is low. If the scanner is more than two years old the battery may need to be reconditioned. It is recommended the battery be reconditioned once a year. The latest revision of the LS4278 manual is here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=134112767&stateId=0%200%2014115220
Print page 28 of 414 and scan the Battery Recondition barcode. The scanner will discharge the battery then charge it up again. It goes through this two times so you need to leave it on the charger a while for this process to complete. Hopefully this will resolve your issue. If not, you may need a new battery.
If the beeps are low, medium, high the procedure above still may work, but you might want to call Motorola for assistance. Sometimes hearing the beeps helps to diagnose the problem.
Oct 05, 2009 | Symbol LS 4278 Barcode Scanner
I want to my m2004 to enter barcode scan after each scan automati
Print Adobe pages 128 and 129 of 302 of the M2000 Series Product Reference Guide and scan the "Scan Options" "Data Suffix" and "Enter" barcodes. The scanner will give two beeps after the first barcode, two beeps after the second and a warble after the third programming (Enter) barcode.
The manual can be downloaded from this link: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969605apdf&sliceId=&dialogID=114420706&stateId=1%200%20114410949
Jul 12, 2009 | Symbol M2004 Barcode Scanner
Symbol ls 4000i not scanning
The first beep is a Good decode beep, the four beeps later are telling that the connection to your PC is not working properly.
Jun 07, 2009 | Symbol LS 4000i Handheld
Symbol LS 4000i scanner issues
Hello, it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from support.symbol.com website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
Aug 25, 2008 | Symbol LS 4000i Handheld
Symbol Spark LS 1004 Problem
What do you mean? you can only scan not more than 3 times? If that so,you need to change the setting of your scanner there was a limit numbers to scan. You can check by using the manual of that scanner.
Hope you like my solution please rate me SOLVE.
Best regards,
Philip
Oct 18, 2007 | Symbol Spark LS 1004
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
