Question about Keurig B60 Coffee Maker
Keurig B60 screen blank
The display screen is not working. Sometimes sections of numbers or words will show through but otherwise its just a blank, blue lit screen that shows.
shannon_m_pe
SOURCE: I just bought it Keurig
I have the same one. fill side tank with water and close down place to put coffee. it should **** up some water. Than in a few it will say ready to use. Hope this helps....
Posted on Jan 26, 2009
SOURCE: New Keurig B60 stopped working!
I had the same issue. I now believe that there was some "vapor lock" type issue. Mine would say the same thing, and i could hear the pump running, but the water level was not changing in the reservoir. I unplugged it, removed the reservoir, let it cool, then tipped it on its back for a few minutes, then on each side. Truthfully I was trying to see if there was some kink in the tubing. Couldn't find a problem, so set it back up and it runs great again.
Posted on Jan 02, 2010
SOURCE: where do I find the serial number for Keurig B60?
remove the drip tray and look on the left front of the machine under the lip where the drip tray fits.
Posted on Jun 02, 2010
  • 10865 Answers
SOURCE: The brewcover on my Keurig B60 broke. Both screw
Hi. go to keurig.com/parts and order what u need. J.
Posted on Jul 25, 2010
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
Continually says Add Water
There should be two little, shiny, metal, poles exposed in the water reservoir. These are used in detecting the presence of water, and must have water between them to conduct electricity, thus completing the circuit. In other words, if these shiny thingys are dirty, or water is somehow blocked from flowing between them, that is why you are having this problem.
Otherwise it's just a defective circuit board, or sensor, either way Keurig should replace the unit free of charge.
Jun 23, 2012 | Keurig Special Edition B60 Coffee Maker
Keurig B60 will not stay on
Turn off Auto Start. see manual page 17 for indstructions.
Feb 23, 2012 | Keurig B60 Coffee Maker
The word "prime" shows up in the window and I
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101';
Sep 17, 2011 | Keurig Special Edition B60 Coffee Maker
My keurig is showing "priming"
heatman101
Sep 16, 2011 | Keurig B60 Coffee Maker
"Prime" is showing in the upper right corner of
heatman101
Sep 10, 2011 | Keurig B60 Coffee Maker
Keurig model b60 display not working not making coffee
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 01, 2011 | Keurig B60 Coffee Maker
When I turn on the brewer, the word "PRIME" appears in the display and the brewer does not start to heat the water.
heatman101
Aug 10, 2011 | Keurig B60 Coffee Maker
My Keurig displays the word PRIME and won't work. What does that mean?
heatman101
May 26, 2011 | Keurig Special Edition B60 Coffee Maker
LED Display window is blank
try pressing all 3 size buttons down and then with them down press menu, wait then unplug and wait 10 seconds or so then plug in and it should have re booted.
Jan 04, 2011 | Keurig B60 Coffee Maker
Keruig Coffee maker (B60)
Keurig alluded to the fact that it is the heating element that buring out and causing these problems.
Oct 25, 2008 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
292 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
