Question about HID Corporation 1351LBSRN PROXPASS TAG PROG RANDOM LEAD FREE
HID ProxPass II - HID Corporation 1351LBSRN PROXPASS TAG PROG RANDOM LEAD FREE
I have a 0402 fault code on my 16 hid xsara what does that mean?
OBD II Fault Code
  • OBD II P0402
Fault Code Definition
  • Excessive EGR Flow
Symptoms
  • Check Engine Light will illuminate
  • In most cases, there are no adverse conditions noticed by the driver
  • In some cases, there may be performance problems, such as dying at stop signs or rough idling, hesitation, misfires or lack of power (especially during acceleration), and a decrease in fuel economy
Common Problems That Trigger the P0402 Code
  • Excessive Vacuum signal or Electrical signal to the EGR Valve
  • The EGR Valve is defective and is opening too far or not properly closing
  • Lack of proper EGR system feedback to the computer from the:
    • Manifold Absolute Pressure Sensor (MAP)
    • EGR Temperature Sensor
Common Misdiagnoses
  • Ignition System
  • Fuel System
  • Oxygen Sensor
  • EGR Valve
Oct 31, 2016 | Cars & Trucks
Hid headlight on 2005 vw beetle won't work
For many European cars, you might need to add capacitor to ensure the HID working properly.
You will probably need this
CAN BUS Error Free HID Decoders Installing HID Conversion Kit
Jan 27, 2014 | Cars & Trucks
How to install
How do you put a casket on a rackin pin on a 1991 Honda accord civic
Jan 12, 2014 | VisionPRO Gen II HID Visionpro 5000k White...
Hid keeps going out
For this problem, you will need a set of HID relay. Using the HID relay, you can directly draw the power from the battery to eliminate this problem.
HID Conversion Kit Wire HID Relay Kit Fuse Relay Harness Wiring
Dec 23, 2013 | 2002 Chevrolet TrailBlazer
On-Board Diagnostic II (OBD II) Diagnostic Link Connector (DLC) Location in 1999 ford Ranger
the ecc diagnostic plug is what ford used b 4 going to the obd 2 system check with ur local ford dealer for checking codes
Jan 08, 2013 | Cars & Trucks
Changed head lights to hid lights now no lights
when iI spoke to hyundi about fitting hid conversions to my Tuson I was told that the engine management system would need updating and a special unit fitted called an ignitor to each headlamp....? I never bothered as the cost was extortionate.
Dec 08, 2012 | 2011 Hyundai Tucson
How do i wire up hid headlights on 2005 mazda 3
To wire up an HID kit on the low beams of your Mazda 3 2005, you will need 3-4 things:
1- HID kit (bulbs and ballasts)
2- HID relay (connects your hid kit to your battery)
3- 4700uF capacitor (solves DRL flickering issue)
4- H7 hid bulb adaptor (you can also use the rubber piece that holds the bulb wires as a spacer)
Wiring diagram:
http://www.carsets.co.uk/upload/temp/images/hid-light-installation-photo-display.jpg
Tips on How to wire up:
1. HID bulb's amp wires connects with the ballast's amp wires. (There's only one way to connect them.)
2. The positive and the negative spade connectors from the hid relay connect with your vehicle's low beam connector, closest to your battery: the driver side. The passenger side low beam connector is not used and should be insulated. You can use electric tape.)
3. Each ballast is connected to one of the relay's clip connector, and it's grounded on each side to your vehicle's body. (One connector for each ballast, one for each side. You can use the screw for the body as a ground.)
4. The red wire(with the inline fuse) in the relay connects to your battery's positive terminal.
5. The capacitor sits on the relay switch. (Google for how to wire the capacitor onto the hid relay switch.) dynoxg image
6. The halogen bulb sits on an adapter. You can safely remove them from each other, and use an H7 hid adapter instead.
For more help: Moonlight Driving
Nov 06, 2011 | Cars & Trucks
2001 landrover dis II headlights are very dim
bulbs wattage may be to high, heat genarated
by them may be to much for plugs try investing in a HID light svstem it uses higher wattage bulbs with out the exsesive heat
Jul 08, 2009 | 2001 Land Rover Discovery Series II
HID fog light
check your connections to the relay, sounds like something is breaking down under load
Feb 18, 2009 | 2005 Chevrolet Silverado
HID headlight
Most likely the HID transformer is not producing the correct voltage to properly charge the HID bulb. 12 volts goes into the transformer, but a lot more comes out. The HID needs a lot of volts to run, hence the need for the abovementioned transformer. But, the transformers are REALLY expensive.
Sep 18, 2008 | 2004 Toyota Sienna
HID Corporation 1351LBSRN PROXPASS TAG PROG RANDOM LEAD FREE Logo
22 people viewed this question
Top HID Corporation Home Security Experts
Lawrence Oravetz
Are you a HID Corporation Home Security Expert? Answer questions, earn points and help others
