Question about Leica DISTO A5 Rangefinder
Battery door broken door
Can I order the door to replace my broken one?
do you mean the door latch , google the door latch as its easily replaceable an obtained
May 19, 2014 | Equator EZ 3720 CEE
Driver side door
Hi Paul, I'm glad to help! Most problems with door handles that won't open the door is broken parts inside the door. Pull the door panel off and move the handle while watching inside the door to see what is broken. Once you've found the broken part, simply replace it. Hope this helps and have an awesome day Paul.
Feb 10, 2014 | 2004 Hyundai Santa Fe
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Oct 26, 2013 | Sanyo Microwave Ovens
Door wont shut
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Miele Dishwashers
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
How do I know if the hinge is broken on the stove door?
the door will fall off when opened if both hinges are broken, if only one hinge is broken the door will drop down on one side.
Apr 20, 2012 | Brown Stove Works Ovens
Battery door not locking nikon s560
hiwould you show the broken area? you can post picture the broken area if you have extra camera. there is one thing you should check battery door hook, post, and battery compartment area. please make sure what really broken then I can help
Jun 03, 2011 | Nikon Coolpix L11 Digital Camera
On drfrost more blows on floor then on dash
door actuator is broken or door pin is broken on the selector door, most likely door pin is broken meaning removing the unit to replace the door inside the heater/ac ducting unit.
Dec 22, 2010 | 2008 Ford F 250 Super Duty 4WD
My battery door is broken I have to put a rubber band around it to hold the batteries where can I find the battery door
Battery doors are almost impossible to find online. I'd contact Fuji by telephone to see if they retail themselves, if not, i'd try and use the broken battery door to somehow replace the elastic band.
Nov 22, 2010 | Fuji FinePix S5000 Digital Camera
The batteries keep popping out when I open the case.
Your battery door or surrounding casing is broken. It's a common problem with this model (especially for units with the side battery door). Unfortunately, your only options are to tape the door shut or get a new calculator. If only the door, and not the casing, is broken you can try to find just the battery door.
Feb 15, 2010 | HP 19bII Calculator
Leica DISTO A5 Rangefinder Logo
50 people viewed this question
Top Leica Optics Experts
woodzowl307
Tom Chichester
Bill Boyd
Are you a Leica Optic Expert? Answer questions, earn points and help others
