Question about Miele Vacuums
Miele hoover model mrg 728 wont start
Model number MRG 728/84-42/2 This hoover stopped and wont turn fuse and plug ok as is the flex
2 Suggested Answers
  • 83 Answers
SOURCE: Just stopped mid hoovering and now won't switch on!
It is probably a thermal cut-off which is caused by a blockage. The machine will turn itself off before it overheats if it is a thermal cut-off. Once it has cooled down, you will be able to turn it back on again (usually 30 mins - 1 hour).
If the machine doesn't turn on at all anymore, you may need to replace the power switch. Call the Dyson helpline, they will do a blockage troubleshoot and if it's not that, they will tell you where you can find an authorized Dyson repair dealer in your area.
Posted on Jul 30, 2009
My electrolux vitesse pet lover 1800w has stopped working
Is the flex all right? Check it with a voltmeter or a continuity meter (available for a small sum in your local hardware or electrical shop).
Jan 19, 2015 | Electrolux Vacuums
Stopped working
the next step would be continiuty to test lead. Measure live, neutral and earth if all ok the motor brushes need to be inspected. Set multimeter to buzzer and test from plug to hoover one at a time.
Nov 05, 2013 | Vacuums
Miele vacum motor dead
would need more info to really isolate problem but you either need new cord reel, speed control board, or new motor. maybe all three. either way a make and model number would help
Apr 02, 2013 | Miele Vacuums
Describe how to change power cord
Before changing the entire power cord, be certain that it is not only the plug that is not working. It is very common for the wire to break inside the insulation at the connection to the plug from flexing and bending. You can tell by plugging the vacuum in, turning it on and bending the wire at or near where it connects with the plug. If the machine stops or starts, it is probably the plug. They are available at Home Depot or Lowes or a local hardware store.
To replace the cord, you have to open the housing where the wire enters, find the end of the wire where it connects to the terminals in the vacuum and remove and install a new wire, maintaining the wire color to all connections.
Gary
Jan 15, 2011 | Miele S251 Flamenco II Bagged Canister...
Our Miele vacuum is only 2/3 years old and seems to have given up the gost, our previous one lasted 15 yrs. The machine starts ok and within 4/5 minutes the power drops down and the hoover comes to a stop...
There is a circut board that is going bad and not providing the power to run the motor. You will need to contact a Miele dealer for that part. It is the only board that is in this machine so they should just need a model number in order to get it for you.
Dec 11, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Hoover Z 700 Model U9145-900
Try going to hoover.com and either email them or there is a number that you can call, this is hoover direct, so someone there should be able to help you. Have your model and serial numbers and purchase date handy in case they ask. It also has a 2 year warranty on it. So if you bought it in the fall of 2006, then you have until the fall of 2008. I would take it to an warranty servicer and get it repaired before the warranty runs out.
Mar 18, 2008 | Vacuums
Miele S758 stops working for no reason
The problem on mine was as described by others. Miele s758 stops for no apparent reason. The first time it happened I had the hose assembly replaced under warranty. Two years later, same problem. I have found that contacts at BOTH ends of the hose were intermittent. I dismantled both ends, extracted both sets of contacts, immersed both sets of slip-rings in methylated spirits and cleaned all the black gunk away. The three PCB mounted contacts were similarly cleaned, retensioned and lubricated with Electrolube. After re-assembly the problem has disappeared. I imagine a repeat procedure will be required in a couple of years.
CAUTION: The procedure is a bit tricky, so unless you know what you are doing, it would be preferable to have it done by someone who does. It is worth fixing as the replacement assembly is $AUD400.
GeeJayL
Sep 02, 2007 | Miele S758 Bagged Canister Vacuum
Vacuums Logo
333 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
