I have a Goodman GMH81005CN Gas Furnace, what kind of thermostat should I use?
  • 108 Answers
SOURCE: goodman gas furnace power vent motor and housing replacement
You need to type GOODMAN GAS APPLIANCES into you browser to find you local servicecenter. I must tell you that Goodman only sells to authorized service companies in my experience. So you become EgKraft Company.
Posted on Nov 07, 2008
aries_67
SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
Posted on Dec 30, 2008
  • 333 Answers
SOURCE: goodman furnace leaking water
Yes you can use regular pvc glue. You should use pvc primer before you glue it.
Posted on Jan 21, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Hello I have a goodman gas furnace
On a call for heat, the 24 volt thermostat2.gif sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the ignitor. The ignitor will glow and you will be able to see it if viewed thru the small inspection port. Once the ignitor gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the ignitor does not energize (bad control, bad ignitor), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not lite (dirty pilot), the burner does not lite (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Most newer furnaces will have a diagnostic center or control built into the control module. You may be able to view it as it is running thru a small viewing port. Some models will require the removal of an access panel prior to finding it. On the reverse of the access panel, there will be a diagnostic chart that will aide you in understanding any error code recorded (usually a blinking light).
Posted on Oct 18, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Furnace does not turn on normally
Having to reset it tells me that there is probably an error code blinking on the control board. Look for a small viewing port that looks into the cabinet. Count the number of blinks then remove the panels to find the wiring diagram pasted on one of them. On the diagram you will find a diagnostic code to help you narrow down the problem. It could be as simple as a plugged air filter.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Feb 09, 2010
I have installed a wood burning furnace and was hoping to run the blower on my goodman gms80703an and thermostat without having to ignight the gas furnace
If I am understanding you correctly, you are just wanting to circulate the air with your gas furnace and heat the air with your wood burning stove. You should be able to set the fan switch to the ON position and leave the heat/cool/off switch in the off position.
Nov 29, 2015 | Goodman Heating & Cooling
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
My gas pack won't light
First, the thermostat white wire is the wire that initiates the furnace to start. When you select heat on your thermostat the tech should get a 24-28 volts between the white wire and common on the thermostat wire in the furnace. If you do not get the required voltage, there is a break in the wire from the furnace to the thermostat that needs to be tracked down and eliminated.
Feb 27, 2014 | Goodman Manufacturing Goodman...
New goodman 80% gas furnace leaking condesation down exhaust vent
it could be condensation. or poor seal at roof. probably the seal at roof. also check the larger copper line is it sealed good? if any spot is not this will cause leaking when in cooling mode. maybe dripping from line onto vent.
Jan 28, 2014 | Goodman Manufacturing Goodman 60,000 btu...
Replacing Goodman Furnace B18099-26 with ICM286 fails
decouple the output of the pcb ,put a 10-100nf between the two connectors
Nov 06, 2013 | ICM286 Furnace Control Board
Goodman Natural Gas Furnace Model GMPO75-3 will not come on
Check to see if you are getting 24 volts at the w-c terminals at the control board of the furnace when the thermostat if calling for heat. Also check if you are getting 120 volts at the L1 terminal and nuetral at the control board, let me know what you find
Dec 28, 2010 | Goodman GMS90703BXA Heater
New Trane XV95 furnace runs and stops nine
if it is a mechanical thermostat the heat ant. does that on cheaper digital tstats it is set by span and on better stats like honeywell model 5000,6000,8000 series you set the cycle rate. what kind and model number is tstat
Dec 19, 2009 | Goodman GDS80904BNA Open Flame Heater
My Goodman furnace wont light.
Open up the unit to get to the control board. Make a short jumper wire and disconnect the wires going to R and W terminals on the board. Connect the jumper to R and W. Depress the door safety switch. The circuit board should indicate a call for heat and the furnace should start. If it doesn't, look for a fuse that may have blown either on the circuit board or in the wiring. If the unit started by jumping the W and R but does not when you reconnect the thermostat, you either have a bad thermostat or a bad thermostat wire.
Dec 02, 2009 | Goodman GMS90703BXA Heater
Have a goodman furnace wont fire check light staying red no errors and i cant smell gas but my gas is on could it be there limiter switches there two upper and lower please help
Probably not, take a small piece of wire and open up the furnace. On the control board find the R and W terminal. It's ok to touch the terminals because the door safety switch will be open. Take that small piece of wire and jump the R and W terminals. Then hold in the door switch to see if the furnace starts. It may take 30 seconds or so so tape the switch closed. If the furnace starts you have either a bad thermostat, broken thermostat wire or a lose wire. If it still does not operate, you have a bad circuit board.
Oct 16, 2009 | Goodman GMS90703BXA Heater
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
