Question about Master Heaters B600D
Looking for electric motor
Looking for 3450 rpm. 1/6 hp Part # m30718-1 Koehring electric motor
Will an electric motor with more horsepower and more rpm hurt a compressor pump?
Electric motors seem to turn around 1125 rpm or 3600 rpm. The pulley size on the motor and pump must be adjusted to achieve the desired result without overheating /loading the motor. I have seen pumps turning from 800 to 1200 rpm using different pulley size on motor, motor hp and motor rpm. Some brands will turn same pump from 1200 to 3600 rpm depending on if was electric or gas motor. This will certainly shorten the life of the pump but will most likely work. Most turn an average of 1200 rpm for good balance of long life and good supply of air. Pump rpm is usually limited to the power of the motor. Cost effective match of 1.5 hp motor will turn pump about 1000 - 1200 rpm for about 5cfm. Rol Air 2hp motor turns 2 cyl pump about 1100 rpm for 10 cfm. Good luck
Mar 17, 2015 | Campbell Hausfeld Tank Air Compressor, 1...
Trouble 3 hp motor
What kind of problems are you having with this motor?
Rod
US Parts Center
May 03, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
How do you wire a type b 3450 rpm mod.c48k2pa105c5 motor to electrical box
two red wires means 220 volt those are both hot green is ground
red to L1 2nd red to L2 then green to ground ( to case) make sure on side of motor it is wired for 220 volt
Apr 03, 2013 | AO Smith A O Smith Motors Century 1hp 115v...
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
Looking for model #2243019204 pond pump motor 2hp 3450 rpm 230 v ph1
This model is a well pump not a pond pump. http://franklin-electric.com/model-search.aspx Did you enter this information in a Google search? locator.aspx">http://franklin-electric.com/dealer-locator.aspx. I also see this pump is available @ Lowes if you live in the USA (please don't say).
I trust this response answers your question.
Thank you for your interest in FixYa.com
Mar 02, 2011 | Franklin Garden
3450rpm motor
MOTOR SHOULD HAVE A RESET BUTTON.
IF U CAN FIND IT, HOLD IT IN-IF MOTOR RUNS
RESET MAY HAVE TO BE REPLACED.MAKE
SURE MOTOR DOES NOT OVERHEAT UNDER
LOAD-THIS MIGHT BE THE PROBLEM.
Jun 21, 2009 | Leeson Reversible Electric Motor 1/2 Hp,...
Master Heaters B600D Logo
104 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Mike Squire
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
