Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
How to bypass samsung scx4305f cartridge chip
You advised me that i should refill the cartridge and change the chip but my cartridge has no chip what should i do after refilling the toner. samsung scx-4300 . what i wand to know is that what do u do to...
The introductory cartridge which comes with printer, it contains no chip, else all Cartridges for this model purchased from Market will have chip. When you refill your cartridge it is obevious that chip needs to be replaced.
thanks
Mar 01, 2011 | Samsung SCX-4300 Monochrome Laser...
I refilled a cartridge for my samsung clx 3175 printer and like couple days after the printer is telling me i have a invalid toner. what do i do to resolve this.
You can resolve the issue by replacing the cartridges with genuine Samsung cartridges. The problem with refilling your ink cartridges is that you do not reset the chip on the cartridge when you do that. The chip on the cartridge tells your printer how many prints that cartridge has printer. By refilling the cartridges and not replacing the chip, you run the risk of damaging your printer. I recommend you pay the full price and swap them out with new Samsung ones and it should alleviate your issues.
Mar 01, 2011 | Office Equipment & Supplies
I bought a new black cartridge and the chip will not reset the machine. had the cartridge company send me a new chip but still never reset the counter. so I have a full cartridge in the printer but it will...
Use the bypass option in the menu - MENU/ENGINE - and then bypass the replace cartridge. It's been awhile since I've done this - but I remember it's under MENU/ENGINE. When you do this both Ready and Error lights will flash - but printer will still print. This will get you by until you can buy a replacement.
For cost-cutting - check eBay. (smile)
Jan 06, 2010 | Konica Minolta magicolor 2430 DL Laser...
How to reset samsung CLT-K409S cartridge
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Aug 20, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-500 problem
Resistors? You mean the smart chips?
Here's something I found over the last few years of dealing with these newer laser printers.
Say for example you had a 13,000 page factory toner, you replace it with a 20,000 page aftermarket refill, but you trade off the chip. There are small case triggers that read the toner size (I still haven't figured if it's internal or external) The chip is programmed for a specific cartridge size. The carts don't match, the chips won't work.
Also, certain printers will recall chips that have been used, and won't let you reapeat chips until you have gone a certain number (like it has to have 4 or 5 different chips before you can reuse the first chip).
So options to get around it.
I found in the Dell printers, if you go through the menus, there is a setting that allows you to bypass using factory cartridges, I don't know if Samsung has the same menu settings, but it's worth digging through the layers.
2) Put the chip that came with it back in, and see it it will work.
3) Break down and buy a factory cartridge. I know this is the least attractive option, but it will determine if it is a read sensor, a firmware/software error, or something else.
The whole smart chip imbedding happened about 7 years ago as a settlement on a lawsuit.
Oct 28, 2008 | Samsung CLP-510 Laser Printer
IP4300 print error message
Try holding the "resume" button (triangle in circle) for about 10 seconds for each cartridge.
If that doesn't work, go to a refill shop and ask if they have a re-setter for your cartridges. Most shops do.
The re-setter gives new serial numbers to the cartridges, so the printer thinks you have put in new ones. Or you can buy one.
In 99%, when the printer tells you that one of the cartridges is empty, it's actually not. The chip is the one that tells the printer when to stop printing. If you bypass the chip, you can continue printing.
Hope that helps!
Sep 12, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
False Toner message
Are you using genuine HP toners? If not HP puts a chip on there cartridges that tells the machine it is a new cartridge. Some generic toners do not replace this chip therefor giving you this false message.
Jun 21, 2007 | HP LaserJet 4600dn Color Printer
Laser cartridges with chips
you need to replace the chips so it will read the amount of pages printed by the toner cartridge.This chip is only for measuring how many pages printed.
Mar 30, 2007 | HP Q2613A OEM Genuine Black Laser Toner...
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
136 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
