Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Kitchenaid (KSCS23INSS00) ICEMAKER NOT GETTING WATER
SOURCE: No water dispensing to the icemaker. Water does dispense through the door dispenser. KitchenAid ksbs25fkbl00
Unplug your refrigerator and leave the freezer door open for 2 hours (The food in the freezer will only partially thaw).
The line supplying the water to the ice maker has frozen...this will un-thaw it.
Posted on Jul 01, 2008
SOURCE: Kitchenaid Icemaker does nothing. Ref. Mod.kscs25Inssoo
This also happened after I changed the water filter. The small black rubber tube that fills the tray was plugged with ice. Instead of hot wash cloths I used a hair drier for a couple of minutes.
Posted on Feb 13, 2009
ginko
  • 19396 Answers
SOURCE: Kitchenaid Icemaker leaking in big drips on front of freezer bins
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
ginko
  • 19396 Answers
SOURCE: Icemaker dosn't work no water going to icemaker but have drinking
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
SOURCE: Icemaker does not work, getting water from the door just not making ice
No, I have not found the solution for my icemaker. I was hoping that I would get some answers from this site. I have the same questions that others had and did'nt have to be refered to your premium support site. So if you can please help me or have any suggestions that would be great.
Posted on May 30, 2009
Kitchenaid french door refrigerator not making ice
Water valve has 2 solenoids. One for water in door and one for water to ice maker. Most likely water valve is the problem b
Sep 16, 2017 | KitchenAid / Architect Series II...
Icemaker stopped working
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
Oct 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
May 28, 2009 | KitchenAid KSRK25IL Side by Side...
Ice maker in my Kitchen Aid side by side is not getting water
there is only 2 things that would cause this. either the icemaker is bad and not calling for water or the fill valve that allows the water to come into the icemaker is bad. how old is the fridge ? also check the ice maker and make sure it has not accidently been cut off inside. if this is the old type theres a bar that raises and lowers. make sure the bar is down. in the up position this would turn your icemaker off
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Icemaker not getting water. I came home to find water all over the floor from my refrigerator. I turned the water supply off in back of the unit and a couple days later started investigating. Changed the...
Feb 18, 2009 | KitchenAid KSCS25FKSS Side by Side...
Kitchenaid icemaker
Most icemakers have a thermal fuse on the black wire feeding them. If this fuse overheats then it will blow to protect your fridge. Check for continuity through the fuse.
(Note that the fuse itself can not be changed. The whole wiring harness has to be changed.)
Nov 03, 2008 | KitchenAid Refrigerators
In door water/ice dispenser not working
check the connect part, see if the gears in the right position.
Jun 17, 2008 | KitchenAid KSRS25IL Side by Side...
Icemaker
Seem that something is cloging the line. Howabout disconnecting both ends of the water line and blow it out with a air hose or air can. Let me know this helps.
Okay, Spurs21
Jan 04, 2008 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
61 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
