Question about Dacor Preference RV36 Kitchen Hood
Button catches on dacor downdraft
Vent sticks
4 Suggested Answers
Rotu
  • 175 Answers
SOURCE: DACOR DOWNDRAFT RV36B PROBLEM
when just the high and low lights are lit, the unit is in childproof mode. try holding down the high and low buttons at the same time until they go out. then if they do, check the response of the other buttons. If this dosen't help, there are really only 2 other options. Most often we see the control board go bad on these (located behind an access panel in the lower right hand corner of the unit below the counter) or the button pad contacts wear out. If the only button that doesn't respond is the up down button, and all the other buttons work fairly easily once its up..then you probably have a bad button pad. If the thing does all sorts of weird things and seem to have a mind of its own, probably a bad control board. the control boards on these fail so often, they re-designed the board to prevent further failures. The button pad is easier to replace and cheaper, so if you have to guess go with that first. good luck!
Posted on Jan 13, 2007
SOURCE: dacor downdraft vent
dacor down draft ventilation won't turn on
Posted on Dec 27, 2007
SOURCE: I have a Dacor downdraft vent RVxx. I find that 2
I just unplugged it again and replugged it. Now it works. Thanks! Renee
Posted on Jun 13, 2009
Why does the power vent keep running?
The auto switch is probably sticking. They are sometimes mounted to sense the vent door open or some are heat sensitive turning on when the flame comes on and heats it up to a certain temp. Check that the moving parts on the switch are not sticking. If everything looks OK you may need to replace the switch.
Mar 24, 2015 | Water Water Heaters
Why do dryer sheets stick to the vent outlet on a Kenmore gas dryer?
The dryer sheets soften during the drying cycle to release the softening material. Air flow through the dryer drum causes the sheets to "glue" themselves to the vent outlet. If you have the dryer disassembled for service, you will find a sticky residue on the back of the vent.
Dec 31, 2014 | Kenmore 73952 Gas Dryer
The oil dip-stick is blown out of its seat when the compressor runs
Without knowing what make or model you have, check the following:
1. Some, not all, compressor dip sticks have venting holes for the crankcase. If the vent holes are plugged or the check ball is stuck the dip stick will get forced out when the piston comes down.
2. Make sure the oil level is where it's supposed to be. Too much oil in the crankcase will cause the motor to work harder and the excess oil being splashed around the crank case can overwhelm the vents in the case or dip stick and again blow the dip stick out.
3. Worst case, you have worn or broken rings on the piston(s), a hole in a piston or a badly scored cylinder(s) and air is leaking past the piston and creating pressure in the crank case and blowing the dip stick out.
Jan 26, 2011 | Campbell Hausfeld Air Tools & Compressors
Passenger side heat doesn't work in my 2007 Dodge Grand Caravan. There is no heat, only cold air, coming from the dash, floor, & defrost vents. There are dual temp controls for the driver &...
I really can't be sure off hand, but what you wrote looks like the control valves are sticking(these flaps allow air to go different directions at the vents). its located at the heater core(towards the left side of the heater core) under the plastic just under the dash. you can manually move them, encase they are stuck, they do stick sometimes. while checking the vent doors, make sure your vacuum lines are connected. also check to make sure your vent hoses are tight. I hope this helps
Jan 11, 2011 | 2007 Dodge Grand Caravan SXT Minivan
I have a 2000 ford taurus with Transmission Fluid coming out of the dip stick. can i fix this myself or do i have to take it in?
There is a transmission vent tube on top of the transmission, & when the vent tube sticks shut, it causes trans fluid to come out of the dipstick (path of least resistance), and/or, the trans pan gasket. This is a common issue w/ the 2000 Taurus. To resolve puncture the trans vent tube.
Dec 04, 2010 | 2000 Ford Taurus
When I start my bike, after 30 seconds fuel backs up in the fuel vent tubes and dumps out on the floor. It backs ups thru the air intake, fills the canister on the end of the vent tube, and over flows...
Float is sticking in one or more carbs. To narrow which one it is, drain each carb seperately,measuring the feul in each carb. The one with the most is the one the float is sticking on. Be sure that the top vent lines are not blocked or colapsed.
Nov 02, 2010 | 2002 Yamaha YZF 600 R thunder cat
How can I replace the two air vents on each side of the steering wheel on the dashboard of my 2004 Acura MDX? I was trying to hang a small holder with a clip that hooks onto the inside of each vent at...
This may be too late in posting. There are some great air fresheners that are a quick, inexpensive fix. The brand you want to look for is called Autoicon1.png Expressions, Ventfresh airfresheners. Pep boys in my area, colorado springs, has a better choice than autozone. They run about 3-4$ for a package of four. AE vent clips look better in the vents than Refresh and other brands which have big round white head that clash with the black.
Auto Expressions Vent Sticks: Wildberries Auto Air Freshener - 4 pk. ' Product Details ' Pep Boys
This is a link for what they look like.
Aug 19, 2010 | 2004 Acura MDX
Where is vent door accuator located in 1996
You will have to remove the actuator motor and stick something into the hole for the vent door,and turn it until it opens,and tie it off to keep it there.
Jul 10, 2010 | 1996 Lincoln Town Car
Transmission works when cold but not when hot.
What you want to check first is the transmission housing vent. If the vent is plugged, air pressure will build in the transmission housing and push fluid out of the dip stick tube.
The vent is located on the top of the transmission housing. You will have to access it from the bottom.
If the vent checks OK, you more than likely have a bad front pump seal that has failed which will involve the removal of the transmission.
Good luck, let me know.
Regards,
Mar 29, 2009 | Cadillac STS Cars & Trucks
Dacor Preference RV36 Kitchen Hood Logo
16 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
