Question about Summit SPWD1800
Summit er 13 - Summit SPWD1800
Sharp AY-XP 12 ER indoor inverter showing -0 14 error
Sharp AY-XP 12 ER indoor inverter showing -0 13 error
Sep 11, 2013 | Sharp Heating & Cooling
What is meaning of this ATM error
*7810*2*E*300050900,M-13,R-10110
what is meaning of this error codes and whats happening for atm machines
Jul 19, 2013 | Summit Appliances Division Youniverse...
I have an error 04 showing on my dishwasher, and the cycle will not run. Please help!
dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Drying Damper - Drying damper not operating
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
Jun 23, 2011 | Electrolux Dishwashers
How do i change the burner tubes on the weber summit
It's fairly easy to do (unlike Ducane Grills). To help you, I have included a link to your Owners Manual, which will really help you. Go to the Maintenance section, Page E-1 for the drawings and description of how to remove the burners.
http://help.weber.com/manuals/pdf_files_2011/Gas/Summit%20SilverGoldPlatinum/OwnersGuides/Summit_SilverGoldB_LP_OwnersGuide_43720_012903.pdf
Hope this helps you to "Get 'er done!"
Happy Grilling!!
May 01, 2011 | Weber Summit Silver B Grill
IGNITION FIRING ORDER SCHEMATIC FOR 1994 EAGLE SUMMIT 1.5 L
1994 Eagle Summit 1.5 liter SOHC L4 VIN "A"
Hope helps (remember rated and comment this).
Aug 24, 2010 | 1994 Eagle Summit
Where can I get a wiring diagram for a Weber Summit Sliver B?
Go to weber.com you can down load manuals and schematics for your grill.
Jun 05, 2010 | Weber Summit Silver B Grill
Summit SPWD1800 Logo
89 people viewed this question
Top Summit Washing Machines Experts
ray gallant
 Russ Hill
Russ Hill
Bill Boyd
Are you a Summit Washing Machine Expert? Answer questions, earn points and help others
