Question about Jenn-Air Kitchen Ranges
Jennaire 8895aas panel out
Back panel went out completely. I determinedboard was getting power so called a repairman. He said I needed a new board. I decided to order one and install myself but got delayed. about two weeks afetr the repair man was here, the pabel started working again. That was 10 months ago. Recently I had occasion to turn the breaker off. When I turned it back on the panel was not lighting up. Tried the sabbaeth escape but nothing happens. Not sure if it is the board or something else and boards are kind of expensive. Any thoughts? I would think loose connection but both the repairman and I moved things around quite a bit and the instance when they went out and in the first case came back on seems random.
  • 1 more comment
  • adam starr Jan 25, 2013
    Rich, Model is definitely JDR8895aas
  • Richard Roth
    Richard Roth Jan 25, 2013
    OK, got it. You are right. You will need to replace the control board. Here is the part to order.http://bit.ly/VwSREo The part comes with a 365 day, any part, any reason return policy so you may be comfortable in ordering from that supplier. Keep me posted!
  • adam starr Feb 13, 2013
    After about 10 days, with no obvious cause, the back panel returned to full functionality, jaust as it had about 11 months ago. If I had replaced the board both times it went out, I'd be on board #3 at this point. Thanka you for your help none the less. I dont doubt there is something wqrong with the board but from the sounds of the comments I have seen, a new one may not be any better.
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
Please check that model number again. I do not get any results with the number you posted.
Thank you!
Posted on Jan 24, 2013
2 Suggested Answers
  • 1073 Answers
SOURCE: Main control panel
need to have a service company check the bottom oven elements first, the replacement part has only a 90 day warranty on it. if it is the control again ???????????????
Posted on Apr 10, 2008
PN59D550C1FXZA 59in Plasma picture comes and goes
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Check the Va and Vs voltages. These voltages should be so accurate as marked on the silk screen behind the display panel. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 28, 2016 | Televison & Video
F-7 error code on jennaire oven
I think that is a problem with the control assembly.
Try first unplugging power cord for ten minutes , and see if this clears the error message.
Nov 01, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jennair 48" completely dead, absolutly no power, no life. Had it repaired, replaced controller board once a year ago cost me $600 but now suddenly just shutoff. Any suggestions?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 17, 2016 | Televison & Video
Tv clixs on and off
check the capacitors and replace the power components.. if not handy with soldering electronics call Tv repairman as you may need to replace capacitors and possibly mother board .. Tv repairman may charge 75-150 dollars depending on cost of Mother board .. good luck
Sep 21, 2012 | Sanyo 42 in. LCD TV
Vizio VW42L went black screen, no sound could turn on but not off, with remote or on the side. Called a repairman, decided to purchase a new TV. Year gone by, plugged it in and it has worked for several...
Yes,the tv main Tuner signal board it is the problems and the causes it have intermittents shorts in sides.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv main Tuner signal boad for the replacement.
Jul 10, 2011 | Vizio 42 in. LCD TV
My brand new lg tv went out and has a burnt smell and one of the usb ports does not work. the tv will turn on, but there is no picture or sound
sounds like the main board need to be replaced. call lg for repair, if no warranty you are looking at $300 for the part plus repairman's fee
Jan 16, 2011 | LG 47LX6500BNDL Complete 3D Bundle 47 in...
I bought a 47 in LCD Television about 7 mos ago one of the speakers went out and I called where bought it and they connected me with a repairman who came out and tested the TV and he said hed return with...
The main board has all the video processing and audio information on it. He should have downloaded the register settings from the old, then onto the new after it was installed. We call those type of people Board Jockey's in our industry. It's not to late if he still has the old board of which he will probably say they sent it back.
Nov 18, 2009 | Toshiba 32HL67 32 in. LCD Television
JVC HD56G887 went out, no sound or picture. Both LED and power lights are blinking
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Jun 24, 2009 | JVC HD56G887 56" HDTV
Jennair 8895AAS
Flustered, first thing I would check is the power. If you are using a 4 wire 240V, part of the copper ground strap just below the terminal block should be removed. You would have black on the left, white in the middle, red to the right and ground to the ground screw just below. 120V from left to center, 120V from right to center and 240V across the outside terminals. If you have it wired right check for voltage at the spark module, should have 120V at terminals L&N. If you have that voltage there and still no spark with your burner caps on (this is the ground for the spark) you more than likley have a bad spark module. Call for factory service since this is new. Catriver..post back.
Sep 03, 2006 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
53 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
