Question about Whirlpool Ovens
Whirlpool RBD245PD06 want to replace upper oven hinges
4 Suggested Answers
SOURCE: Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Posted on Aug 06, 2009
  • 1891 Answers
SOURCE: repalce a broken door hinge on upper oven
you must remove side panel . if wall oven slide out on a table strong enough to support is during service . mm
Posted on Jul 16, 2010
SOURCE: Model KEBC277 Kitchenaid oven - I need to remove the upper door, but can't figure out how to unlatch the hinge
there will be two hinge latches that you flip to stop the door from closing. This will allow you to push the door in and then pull out the bottom. I do not suggenst using the handle as it may cause damage. use one hand on either side of the door, push the door shut and then lift up a bit and pull the hinges out of the holes.
Posted on Oct 26, 2011
Repalce a broken door hinge on upper oven
Jul 16, 2010 | GE Profile JTP56 Electric Double Oven
How to remove door for whirlpool oven RBS305PDB2
open the door about 1/3 of the way and lift it off the hinge pins. it helps to have two people do this. when it is time to replace it, put the hinges in that 1/3 open position and slide the door back down on.
Oct 02, 2009 | Whirlpool RBS305PD Electric Single Oven
Last year, my 8 year old Whirlpool oven door would not stay closed all the way. I ordered new hinges, replaced them and it was great for 11 months. Still under warranty, I replaced them a second time......
Are you replacing the hinge guides as well? The hinge is usually only one half of the problem. When you remove the door, look into where the upper long arm of the hinge resided. You will see a little runner wheel. Touch it with a thin screw driver and see if the wheel feels loose. I'll bet at least one of them is!
Jun 25, 2009 | Frigidaire 24" Single Gas Wall Oven with...
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
My oven door will not shut tightly
Hi, I take it that this a whirlpool oven? Single or double oven? If it is a double your in luck! Your door hinges need replacing along with the inserts that are located inside the oven cavity. You can exchange the hinges and inserts from the oven doors and hinges if you have a double oven. If not get some new ones and fit them in! Easy job you will just need a little guidence as some models do differ..
Get back to me if this is usefull.....
Dec 30, 2008 | Whirlpool Ovens
Whirlpool Double Oven RBD305PDB7 - Upper Oven Won't Heat
I have the single oven of this style and I had to replace the thermocouple (part number 4450934) on the back of the oven three times (used the cleaning cycle three times). After using the cleaning cycle, the oven would not heat so each time I had to pull the oven out from the wall to access the back so I could change the part. Once a new part was put on the back of the oven, it worked fine. To pull the oven out, open the oven door and look down by the doors hinges. On each side you will see a screw that's holding the side molding on. Remove the screws and then the molding. That will give you access to the screws that hold the oven into the framing around the oven. Remove the screws and then you can pull the oven out to access the back to change the thermocouple. The oven is heavy so you may want some help to get out. It is not a one man job, maybe a one man and wife job. It is heavy. I hope this helps. Better late than never.
Aug 23, 2008 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
53 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
